87-T2 injector swap
Old Feb 16, 2005 | 06:24 PM
my-sons rx7's Avatar
87-T2 injector swap
Does the 720cc fit in the stock primary rail, or do you need to mod it. I search and could not fine the answer. Thanks Tony
Old Feb 16, 2005 | 07:31 PM
hondahater's Avatar
spending too much money..
yep it sure will.
Old Feb 17, 2005 | 05:11 AM
Originally Posted by hondahater
yep it sure will.
WoW thats easy, Dam nothing goes that easy for me. it seem like i have to search for days to fine the answer. Im new at all this, any tips or advice would be appreciated. Thanks Tony
Old Feb 17, 2005 | 06:00 PM
RETed's Avatar
It'll drop in, but how do you compensate for the larger capacity injectors?
Engines tend to hot-start flood if you have no way of adjusting for the larger capacity.
-Ted
Old Feb 17, 2005 | 06:02 PM
drewl's Avatar
Flame Thrower
is safc good enough for 720's?
onePOINTthree's Avatar
N/A is teh WIN!
a couple ways you can control fuel, S-AFC, Greddy E-Manage or go all out and get a standalone like Haltech
Old Feb 17, 2005 | 06:08 PM
RotaryEvolution's Avatar
Sharp Claws
the ECU has a preset amount of fuel injected during cranking, an SAFC cannot compensate for that so it may cause some hot starting problems, maybe even cold starting ones depending on your compression numbers.
The Shaolin
Sep 14, 2015 07:50 PM
86rxNa
Aug 11, 2015 11:51 AM
