Loose alternator belt...
Old Feb 16, 2005 | 04:21 PM
Jwowl's Avatar
Question Loose alternator belt...
Can a loose alternator belt cause the pulley (on the alternator) to heat up to a very high temperature and cause the belt to snap?
I was told my alternator was done for but i noticed the belt was really loose so i thought it have something to do with that.
Old Feb 16, 2005 | 04:43 PM
Project84's Avatar
Open up! Search Warrant!
the belt will break from the friction of the metal pulley scrubbing against the rubber belt. I don't think that the friction from the belt against the pulley will cause damage to the internal components of the alternator.
Old Feb 16, 2005 | 05:12 PM
Jwowl's Avatar
Well my pulley was heating up really bad and i was told the alternator needed to be replaced (bad bearings was the verdict), but the belts were replaced by these guys who didn't properly tighten the alternator belt... so i figured that's why the pulley was heating up.
as for the bearings, I'm not quite sure how to tell whether they're good or bad, but i have an alternator coming so i'll probably replace it anyway..
Old Feb 16, 2005 | 05:56 PM
Kenteth's Avatar
Like Ghandi with a gun
Well, if the alternator pulley is hard to turn, its not hard to believe that the belt will slip on it rather than actually turn it.
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
