How To Remove Front Brake Dust Shields
Old Feb 16, 2005 | 03:21 PM
sktrowley's Avatar
how the *&% do you get the front dust/brake sheilds off?
Old Feb 16, 2005 | 03:25 PM
Wizz's Avatar
4 10mm bolts.
Think you might to take the hub off too.
Old Feb 16, 2005 | 03:59 PM
sktrowley's Avatar
how exactly do you do that?
Old Feb 16, 2005 | 05:10 PM
uRizen's Avatar
XBL** Ownicus
Check the axle section of the FSM. You need to remove the hub nut and pull the disc and hub off then the shield comes off last.
Old Feb 16, 2005 | 06:07 PM
onePOINTthree's Avatar
N/A is teh WIN!
BTW make sure you clean and inspect the wheel bearings when you pull the hub. Wheel bearing grease dosen't last forever and it's probally a good idea to replace it while it's apart. Just a thought BTW order up some Neo Synthetics bearing grease, the stuff works wonders
Old Feb 16, 2005 | 09:47 PM
sktrowley's Avatar
alright thanks guys
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
