Replacing FPR solenoid
Old Feb 15, 2005 | 07:46 PM
rekx's Avatar
Yar Matey!
I have decided to put myhot start solenoid back in, but i seem to remember it having a broken nipple. Can i pull any it the solenoids with the little breather to replace it? or do i have to get one from mazda
Old Feb 15, 2005 | 10:01 PM
HAILERS's Avatar
HAILERS
Any one of the solenoids will do. Wrecking yard will have them.
Let's see. If the nipple was broken, and that nipple was b/t the FPR and the solenoid, then you have been seeing 100 percent of the time, the atmospheric pressure that the FPR solenoid gives when it's energized for hot start. Or approx 38psi all the time on a non turbo car.
What you would not be seeing, is the fuel rail pressure being regulate at any other pressure other than approx 38psi.
Or, if that did not make sense, this will. During hot starts the normal RX-7 sees atmospheric pressure at the fpr and the fpr puts out approx 38psi.
When it's not seeing a hot start situation the fpr regulates b/t approx 28psi and 38psi.
High rail pressure during HOT START. Talking n/a's. Turbo similar.
All those solenoids are the same animal. As Icemark has said, the only difference is where the breather is installed on the solenoid. It can be pulled off and reinstalled on the other port on the solenoid.
They all get a constant 12vdc on one wire and a ground on the other wire from the ECU when the ECU decides it should have a ground. Something like that.
Old Feb 15, 2005 | 10:29 PM
rekx's Avatar
Yar Matey!
no no, i broke the nipple when i removed the rats nest, and now im having some hot start issues so im gonna throw it back on
Old Feb 16, 2005 | 12:10 AM
HAILERS's Avatar
HAILERS
In short........if the nipple is broken, then the fpr thinks its in a hot start mode all the time.
Old Feb 16, 2005 | 06:18 AM
rekx's Avatar
Yar Matey!
no you still misunderstand me, i know what happens when the nipple is broken, i am asking if it is replaceable with any of the other solenoids that have a breather
Old Feb 16, 2005 | 08:01 AM
HAILERS's Avatar
HAILERS
Yes, any of them. There are two arrangements of the same solenoid. Look at the filter on them. It's in a different place on some vs the other. That filter pulls straight off. So either pick one that looks exactly like the fpr solenoind, or pick one of the others and arrange its filter to look just like the fpr one.
I wrote that in my first post towards the bottom.
Old Feb 16, 2005 | 08:17 AM
rekx's Avatar
Yar Matey!
yep! thanks!
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
