Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D What size injectors would you recommend?
Old Feb 1, 2005 | 11:12 AM
Bentot's Avatar
I drives the Avalanche
I cant spell for **** so shoot me
anyways, I am getting the Wolf 3D system installed right now, I am wondering what size injectors would best suit my situation...
I am going for streetability right now and power later...
I have a 3" DP and full exhaust
T4 turbo
Full Race port(Autodemics/Reactive Racing)
3MM Apex seals
6000 miles since last rebuild
3rd gen rotors
intake
BOV
will have FMIC by summer time...
someone please help me out!
Old Feb 1, 2005 | 11:45 AM
eViLRotor's Avatar
Brother of the Rotary
I run 720cc primary, and 1600cc secondary. That is enough fuel for 400whp+.
The Wolf V4 staging is very smooth, so you won't have any transition issues which can occur with other EMS.
Old Feb 1, 2005 | 12:22 PM
nyt's Avatar
nyt
i had headroom with 550 primaries and 1680 secondaries with everything else stock except a walbro pump. i was making over 430 to the wheels
Old Feb 2, 2005 | 02:50 PM
Bentot's Avatar
I am also worried about idle problems with such big injectors....
but I do plan on over 400 whp, but only care now for streetability until I get another car..
so thats 2 votes for 1600cc injectors
thanks
Old Feb 2, 2005 | 11:02 PM
eViLRotor's Avatar
My car idles fine with the 720's. I know 550's will idle fine
Old Feb 3, 2005 | 12:16 AM
nyt's Avatar
nyt
idle problems are a myth =] ive idled a car fine on 1600 primaries =]
Old Feb 3, 2005 | 07:29 AM
my car idled better than stock with 720 primaries
injectors are not a miracle fix tho, without the volume of fuel to back it up 4 x 1600cc injectors still isn't going to support much power.
a buddy of mine just dyno'd 230 to the wheels with 4-550cc injectors at a stock fuel pressure, and he actually had to use a s-afc to lean out the fuel in higher rpms.
get a sufficent fuel pump, larger hard line, larger line in the engine bay, aftermarket fpr, larger rails, and you'll be amazed what kind of power medium sized injectors can support.
Old Feb 9, 2005 | 06:53 PM
Bentot's Avatar
I got a GTR fuel pump already, working on a FPR and lines...However, I just had Carb Conn order me some 750 RC Engineering injectors and Ill swap those over to the primaries when I get bigger injectors for my secondaries later on..
thanx for all the input guys, I cant wait until I get my car back, I just need some better tires on the slicers I got from someone to replace my stolen rims
Old Feb 12, 2005 | 12:26 PM
Fatty_FC3S's Avatar
1600s will be just fine. The wolf has fantastic staging abilities so you can make everything come "online" very smoothly. Its always funny to see a map with a "staging bar" programmed into it because the user is thinking "old school ems". DONT DO A STAGING BAR (a spot where injectors go from off to 100% instantly). You will be happy :-)
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
