Flywheel: aluminum vs. chromoly
Old Dec 15, 2001 | 03:11 PM
Any comments on whether the chromoly is worth the extra money over a steel faced aluminum flywheel?
Thanks
Old Dec 15, 2001 | 03:26 PM
JoeD's Avatar
the material doesnt matter. its the weight of the flywheel.
a lighter flywheel will make your car revv up hella quick, but it will be a pain in the *** to drive in stop-n-go traffic.
most people go with a 9.5 pound flywheel for street applications. you might wanna upgrade your clutch while you're at it too. a 9.5 lb flywheel and ACT Street/Strip clutch is the most common combo.
Old Dec 15, 2001 | 05:25 PM
Rx7-AIII's Avatar
I thought that although aluminium is cheaper it has a tendancy to warp if abused and may come apart if vivited. Steel although heavier is stronger. If weight is removed peripherally the heavier steel flywheel will be just as effective.
LongDuck
Oct 7, 2015 08:12 PM
GKW
Sep 28, 2015 04:34 PM
