Stock BOV blows off when 1/2 throttle
Old Dec 15, 2001 | 12:54 PM
Question Stock BOV blows off when 1/2 throttle
I did stock BOV mod.
I like the sound it makes and I can be sure my turbos working.
But it's keeping blows off air when 1/2 throttle.
IS it normal?
Thanks..
Old Dec 15, 2001 | 01:27 PM
widebody2's Avatar
addicted to lounge
I have the apexi one and it does the same thing...Does yours not blow at wot? mine blows between shifts at little throttle and wot. anything in the middle it is blowing the whole time. I wish someone else would have answered because I was wondering if something was wrong too. I actually think it is fine because my car seems to be ridiculously fast so I'm not worried. Do you happen to have a power fc or apexi avc-r? My bov used to just blow between shifts before I had mine. How much boost do you run?
Old Dec 15, 2001 | 01:49 PM
JoeD's Avatar
throttle percentage has nothing to do with a blow off valve blowing. (:p ). its all about the boost. you could be at full throttle, in 5th gear for example going 10 mph....the bov wont blow because you are not spinnin boost.
Old Dec 15, 2001 | 02:02 PM
Donovan's Avatar
Hi sir
A blow off valve is used to release excess boost as to not have it cause damage. It blows between shifts because as the throtle closes between shifts (letting off the gas)the pressure has nowhere to go and would slam back against the turbos and but a lot of stress on things like the intercooler and pipes. The valve releases this pressure.It blows at lower RPM and partial throtle because the motor is not using the boost that the turbos are producing.
Old Dec 15, 2001 | 02:47 PM
martini's Avatar
Think about it...if you're at half throttle, you don't need the boost, do you?
As soon as you go WOT, it will pinch the BOV shut.
Queppa
Nov 18, 2024 03:47 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
