What type of bondo to use?
Old Jan 19, 2005 | 09:18 PM
Dan_s_young's Avatar
Turbo widebody FB
Well this is a pretty stupid question... But im prepping my 85 rx7 for paint and im just curious what type of bondo I should be using. I have used some sqeeze tube container type bondos and they seem to suck, should i just buy a tub of it and a plastic blade to apply it? Im using it to fill some holes, if that makes a difference.
Old Jan 19, 2005 | 09:44 PM
w4rdr1v3r's Avatar
1 4r3 4 L337 M4s73R
bondo glass.
Old Jan 25, 2005 | 11:42 PM
bradt's Avatar
I personally wouldnt use bondo, i would solder or braze it myself
Old Jan 26, 2005 | 02:31 AM
1revn3rdgen's Avatar
The one your using is the wrong one, it's a green one right?it's not really bondo it's glaze, that one isn't for big job, and as many people call it putty-bondo it's for small jobs and gives you a good quailty finish.You should by dynalite or 3m bondos
Old Jan 26, 2005 | 08:31 PM
EKTwin93's Avatar
If your just filling small cosmetic imperfections, the grey bondo body filler works great. Just make sure you prime it right because it can absorb moisture. I find the fiberglass resin jelly(green stuff) too hard to sand for stuff like that, but it is much stronger when you need it.
Old Jan 26, 2005 | 08:33 PM
EKTwin93's Avatar
If your just filling small cosmetic imperfections (dents), the grey bondo body filler works great. Just make sure you prime it right because it can absorb moisture. I find the fiberglass resin jelly(green stuff) too hard to sand for stuff like that, but it is much stronger when you need it. If you are actaully filling a hole in the body, I would use that.
Old Jan 26, 2005 | 08:34 PM
EKTwin93's Avatar
ahh sorry for that repost
Old Jan 27, 2005 | 12:02 AM
Turbo widebody FB
ya i got some of the green fiberglass bondo, it is a pain to sand but hopefully it will be worth it in the end. To clarify with it im fixing dents in the side of my car where i removed trim and im shaving my side reflectors, antenna, badges, and headlight squirters. Hopefully should look nice and clean once i get it all cleaned up and painted.
Snook
23
Sep 30, 2015 11:36 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
