Gsl-se Mixture Adjust Screw
Old Dec 13, 2001 | 11:58 PM
rxseven's Avatar
Special Dark
Question, can a bad mixture adjust screw/variable resistor by the AFM lead to a no start situation? Has it happenned to anyone before?
Old Dec 14, 2001 | 03:00 AM
hanman's Avatar
there are a ton of things that can lead to a no start situation. Give us a little more information. Does it crank over well, fuel to the chamber, good spark, etc.
Old Dec 14, 2001 | 04:19 AM
Max7's Avatar
Admitted Sevenaholic
I belive the mixture screw is only for setting idle fuel mixture. so that should'nt cause a no start situation.
Old Dec 14, 2001 | 01:01 PM
rxseven's Avatar
Special Dark
Well, the problem is I have checked compression, spark, fuel pump. All OK. But the car will not start. If I put some starting fluid in the intake, it'll fire-up for a second and then die. Before all this happened, I had a short that kept blowing the engine fuse. I found it to be the one connecting the air supply valve for the a/c. I now believe I have an electrical problem which is either preventing the injectors from opening or I am not getting enough air. Last night, after trying to start it, I removed the plugs and saw some fuel but not a whole lot. Infact, the trailing plugs had only splatters of fuel. When I propped the afm door the injectors sprayed the fuel, so I know they work. What's left?
Bad AFM or CPU????
I am open to any further suggestions.
DerpyToast
14
Nov 23, 2024 05:19 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
Ernstudet22
Sep 14, 2015 09:19 PM
