S4 to S5 engine, Do I do S5 ECU???
Old Dec 13, 2001 | 10:16 PM
rotarymaz's Avatar
Hey guys, if I go from a series 4 TII engine to a series 5 engine, will I need the series 5 ECU or any other wirings?
Old Dec 13, 2001 | 10:25 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you need everthing, the ecu, wirring harness, pressor sensor, AFM, all manifolds, injectors, etc.
or nothing. by using the bare series 5 block, with all the series 4 stuf bolted onto it. manifolds etc.
Old Dec 13, 2001 | 10:26 PM
ryanj's Avatar
Yes, you can put the series 5 ecu and wiring harness in with it but that is a pain in the ***. Just swap all the stuff off your s4 engine on to the S5 block, or get a haltech.
Old Dec 13, 2001 | 10:27 PM
ryanj's Avatar
beat me to it
Old Dec 13, 2001 | 11:11 PM
rotarymaz's Avatar
If I use the bare S5 block with all the S4 stuff, I wouldn't be able to use the S5 turbo, right? Is it worth it to upgrade to the whole S5 setup or am I better just sticking to a rebuild/use S4 engine? Thanks
Old Dec 13, 2001 | 11:55 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you are better off to stick with the same year block. the 89-91 turbo and manifold will bolt on and is an upgrade. recommanded if you plan on doing any mods. it has a much better wastegate.
C. Ludwig
Jan 30, 2019 06:31 AM
freq
Microtech
Aug 23, 2015 11:02 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
freq
Aug 21, 2015 03:30 PM
