Haltech Wrong Setup?
Old Jan 18, 2005 | 02:30 PM
Edwinboost's Avatar
Newbie
Question Wrong Setup?
Originally Posted by Edwinboost
I recently installed an E6X to an RX7 93 Twin Turbo. I installed the wiring exactly like the K2RD Wiring diagram and the instructions you gave a guy in the forum. Also, I imported the maps from an E6K that is installed in another RX7 93. But I having some problem in the startup. The engine start for 2 or 3 seconds and then stall. I not very sure about some areas of the set up I'm using, so this is what I have:
ECU ---- Advance
Ignition Divided --- 2
Trigger angle BTDC ----63
Tooth Offset ------5
Trigger Type ----- Multitooth
Trig input pull up on ---- Selected or enable
Aux/Out ----- Ignition toggle (the green/black lead from the E6X to the rear trailing ignitor)
I would apreciatte any help on this.
Thanks.
Edwin
Old Jan 18, 2005 | 02:41 PM
RETed's Avatar
Have you shot the ignition with the timing locked?
If it starts, it sounds like the igntiion timing is fine.
The base fuel map or coolant map might need to be tuned.
Don't assume someone elses map is going to work on your car...
-Ted
Old Jan 19, 2005 | 08:24 AM
Bukwild's Avatar
edwin I am having the same problem as you. What type of injectors are you running. I am running a 720/1600 combo and mine starts then floods out. Got to be someone that knows how to fix this in these dam e6X's.
Old Jan 19, 2005 | 01:12 PM
Edwinboost's Avatar
Newbie
Same Injectors
I have almost the same injectors (850cc and 1500cc). The car was running with an F9 just fine. I'm just started to work with the maps and setup.
Shainiac
Jul 17, 2019 02:20 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
