Haltech Tuning w/ the Haltech, and O2 sensors?
Old Dec 13, 2001 | 03:25 PM
Manolis_D's Avatar
How do people usually tune their cars once they get the Haltechs installed? If you do it yourself, do you use a Wideband O2 sensor (and if so, which one?)
Are there any shops around Southern California that can do this (at least the 1st time, until I get the hang of it)? What does that usually cost?
Thanks!
Manolis
Questions Galore...
Old Dec 13, 2001 | 07:31 PM
tims's Avatar
chassis dyno runs about $100 to $150 an hour depending on the operator. A good operator familiar with Haltech can do most cars in 3-4 hours. road or track tuning can be done with an O2 sensor or EGT, this is not a simple thing to do and could cause terminal engine failure if done wrong.
Old Dec 16, 2001 | 02:16 AM
Rx_treme's Avatar
for the most part a stock map will work fine. i have been using the stock HITMAN map for like 2 months and no problems at all. really fast too on this setup below..... but i will be switching to a map for the 1600's this week.
jason
Old Dec 16, 2001 | 11:33 AM
Manolis_D's Avatar
Hey Rx_treme...
Is the stock map maybe a little lean for a DP, etc?
On another note, how'd you manage to shoehorn 245/45R17's under your car? (are they on the front too?)
Thanks!,
Manolis
Old Dec 29, 2001 | 12:19 AM
Rx_treme's Avatar
it runs pretty good but on sunday i will be putting my 1600's, upgraded rail, walbro pump, and better map in so we'll see how it runs after that.
The 245's fit fine. I originally had them on there with 1" spacers but when i hit any gas or turned kinda fast it would rub really bad. so i took em off and it fits fine.
On the front are 225/45/17's that very rarely rub.
jason
Old Dec 29, 2001 | 03:35 AM
Manolis_D's Avatar
hey Rx_treme...
Thanx for the info on the tire sizes -- Much appreciated!
on another note, (now i'm just being a pain in the ***, i know :p )
Any word on the driveline stuff? :-)
Thanks ,
Manolis
Old Jan 1, 2002 | 04:36 AM
Rx_treme's Avatar
well still have not gotten the driveshaft however do you want me to send you the diff with the halfshafts? i can do that then send the ds when it arrives. email or PM me.
jason
