hood
Old Jan 14, 2005 | 07:41 PM
dregg100's Avatar
hood
couple of hood questions,
will a v-8 fit under a Tii hood?
if not, where can i get a hood that will fit a v-8?
or will i have to make it?
Old Jan 14, 2005 | 07:44 PM
IaMtHeRuThLeSs1's Avatar
I'm awesome!
www.torquecentral.com
www.grannysspeedshop.com
you should have searched first...pray a mod. deletes this thread before anyone else can repond.
Old Jan 14, 2005 | 08:56 PM
NoRotor10AE's Avatar
10AE LS1 Swap In Progress
Talking
too late! mwahaha!
What! you bastard! you're going to put a V8 under the hood of your blessed rotary! I'm going to come kill you and take your car! Leave the soul of the car intact!!! You suck at life!!!
oops, my bad.. i've been readin too many non-rotary rx7 conversion threads lately... what i meant to say was "Good job! Post pics!" Glad to see another soon-to-be V8-7
Old Jan 15, 2005 | 12:27 PM
REnder's Avatar
Why would you want to swap out the rotary for a V8?
Old Jan 15, 2005 | 04:30 PM
Crash Test Joey's Avatar
Zero Rotor Motorsports
Reliability, power potential, torque, mileage.... Search this section of the forum and you'll understand
Old Jan 15, 2005 | 04:49 PM
skrewloose78's Avatar
Anti-rice Superstar
what type of v8? i know a lt1 and ls1 both will fit. check out www.wrongmotor.com
Old Jan 16, 2005 | 11:04 PM
QuasiMofo's Avatar
eVilallianceracing.com
Amazingly the same question (Posted by REnder
Why would you want to swap out the rotary for a V8?)was aked on the GRM forums ( GRM Forum here ) and I got sarcastic in my responses!
Not everyone likes paying big money to replace the necessary parts and pieces or to hop up their rotary mill. Hell the only reason why I am installing a 4.2L V6 Ford engine with an Eaton Supercharger is because I had it and it was free!
Cost of swap:
RX7 - $100.00
Tbird SC - Free
4.2L Core engine - Free
Focus fuel pump (and tank) - $25.00
Engine mounts - $31.00 home built
C4 tranny - Traded AOD
7.5" 1998 Ford Mustang rear axle modified to be installed using factory RX7 Watts - $100.00
Shortened alloy driveshaft - $41.00 balanced
FD3S brakes all around with adapters and proportioning valve - $192.32
16x8" front 17x11" rear wheels with 265/45r16 Kumho Victoracers and 335/35r17 Michelin Pilot slicks - $130.00
I am at $619.32 as of 01/01/05 and still need to buy a gasket set ($132.00) Head bolts ($40.00) shifter and seating (hello eBay!).
The best part of my car has been in the hunt for this stuff. As much of an oddball as it is I am letting it take it's own direction!
I wanted a non rotor mill because I couldn't afford it.
Got a free Super Coupe from work (salvage yard).
Wanted 5 bolt hubs found someone parting a FD3S and got the brakes and all.
Needed wheel and found massive and ugly old ARE stuff with wrong offset for cheap, couldn't use without wider rear axle, had Mustang axle in gaage from Datsun Raodster project that has stalled. Mustang rear perfect width AND FD3S brakes can be made to fit axles
Alloy driveshaft from late model Mustang had a minor dent in very rear of unit making it unsellable. I cut it with a plumbing pipe cutter to length, kept it clocked at the same locations, then pressed it back together like the factory did. then had the balancing done
All the work in this car has been done and will be finished for less than a competent stock 12a rebuild. plus it will be unique, no other idiot would eVer think of building one like it!
Old Jan 17, 2005 | 01:00 AM
You're going to have one bastard of a car haha
but props for the thought behind it
Old Jan 17, 2005 | 09:31 AM
owen is fat's Avatar
right on... the newer GM v8's that have fuel injection and a forward facing throttlebody will fit without any clearance issues, even with a non-turbo hood! (sweeeeeet!) see my homepage for pics if you wanna see an example.
Old Feb 1, 2005 | 01:21 AM
I'm awesome!
Cost of swap:
RX7 - $100.00
Tbird SC - Free
hmm...i thought the T-bird supercoupe only made like ~200hp...plus I'm pretty sure that engine sucked ***, I had a 94 T-bird back in the day. You're putting this in a FD?hm...nice to see you save money, I just fail too see if you'll make more power than a stock FD...
idk...you've been resourceful so far I'm sure you'll do the same w/ the whole engine thing.
it is a thunderbird supercoupe right?
ls1swap
Jun 3, 2024 03:25 PM
