Choosing a Turbo for my T2
Old Jan 10, 2005 | 06:45 PM
igottafc's Avatar
RX7less **(
well im going to be in the market for bigger power pretty soon so im going to start now. Im looking to make around 300-350hp. Im looking for something very quick spooling with engine response as my main goal in mind. my mods are listed in my sig which ill probably retain a similar setup to what i have + fuel components. Im looking to spend about 1200 at the most for a new unit. -alex
Old Jan 10, 2005 | 07:29 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I run a 91 JDM TII motor in my FB
Im running a moderately rewelded Obx stainless manifold and a ebay special To4b turbo
the turbo is 1.15 p trim divided on the exhaust and a 60 trim on the cool side.
Although I was not able to fully boost it because of a problem with my haltech. turbo spool up seamed to be VERY fast and engine responce was good considering the haltech was not tuned.
sorry I cant give you more info, but I was only able to drive the car for two weeks before i had to put it away for the winter.
Old Jan 11, 2005 | 11:51 AM
igottafc's Avatar
RX7less **(
now im still kind of new to this and im gathering up as much info as i can. What does the trim of the turbo actually represent?
Old Jan 11, 2005 | 12:37 PM
Mark'sMazda's Avatar
stop stealing my avatar
Wheel "trim" refers to the squared ratio of the smaller diameter divided by the larger diameter times 100. Usually, the larger the trim, the more flow the wheel has. This whare the "dude, get a 50 trim turbo" comes from.
Most people will use P trim on a street car. Q trim flows more exhaust and is more for making big numbers, in a small'ish power band.
making that much hp will be either really pushing a hybrid, or no sweat for a full upgrade. If you have the coin, id go w/a t04b 60-1, .84 a/r with a divided foot print. Doing this will require a fmic, standalone, wastegate, and mani though...
If not a hybrid will get you close, if not make your power level.
Old Jan 11, 2005 | 02:13 PM
igottafc's Avatar
RX7less **(
Thanks mark I went to the MI club the other day and signed up. How did that tranny install go?
Old Jan 12, 2005 | 07:12 PM
cool, hope to see you around.
I have a t04e hybrid .68a/r, bored 3" from turbine through back plate. It should make 300hp at the wheels..but we'll see when i get the bugs sorted.
How much are you planning on spending on the upgrade?
Old Jan 14, 2005 | 09:32 AM
Mills's Avatar
procrastination engineer
I was told a T04e 57 trim would make close to 400hp with porting.
That would put stock ports at 360-370hp or so (w/haltech) was I misinformed about this turbos capabilities?
Old Jan 14, 2005 | 10:03 AM
eViLRotor's Avatar
Brother of the Rotary
I'm sure the 57 trim could make 400whp but with a lot more boost.
If you are looking at 400whp at around 1bar, then go with the T04E '60' trim, or a T60-1/T04S (the preferred choice).
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
