13b re and turbo...who's running
Old Jan 9, 2005 | 07:53 PM
viperkiller7's Avatar
1.3 liters of whoop ass
Who is running the re motor and what turbos are you guys using. just curious as im staring my project now. id like to see some pics of your cars to. oh yeah like to see dyno sheetys to
Rodney
Old Jan 9, 2005 | 08:02 PM
the_glass_man's Avatar
Will u do me a kindness?
Rodney
My friend is going to be running one in his FC probably with a T04S. The engine isn't even together yet, but the porting is done and should be put together in a few weeks.
Old Jan 9, 2005 | 08:06 PM
does he have the turbo yet i have a to4s for sale
Old Jan 9, 2005 | 08:16 PM
RETed's Avatar
What makes the Cosmo 13B-RE engine that much different than a 13BT or a 13B-REW?
Turbo applications work for all these engines...
-Ted
Old Jan 9, 2005 | 08:22 PM
GOTBANNED?'s Avatar
Boost Addict
intakes are much bigger on the re!
Old Jan 9, 2005 | 08:24 PM
wanna get some ideas thats all
Old Jan 10, 2005 | 01:28 AM
RETed's Avatar
In what way?
Are you talking about cross sectional area of the intake ports of both the primary and secondary?
Or are you talking about just the secondaries?
I think the 13B-REW has more cross sectional area of both the primary and secondary intake ports.
If you're talking secondaries, then you're correct.
But, I still don't see how this affects turbo sizing?
Displacement is still the same, right?
-Ted
Old Jan 10, 2005 | 11:19 AM
FD Rey's Avatar
I brake boost
My brother has a TII powered by an RE with a GT40 turbo. He's working out the bugs, will put in a Microtech soon too. That being said, no dyno # yet.
Old Jan 10, 2005 | 11:43 AM
RacerX_IU's Avatar
im currently working on putting an RE into my FD. i have not yet decided on what turbo set up to go with. All of the intake ports are massive in comparison to the FD ports, but the RE exhaust ports are noticeably smaller. This is playing a factor into my turbo decision. i am pretty sure any of the fd kits fit ok on the RE.
Old Jan 10, 2005 | 01:04 PM
Jon Goodwin's Avatar
Consider using FD housings...
John
88 GT-R
Old Jan 10, 2005 | 05:55 PM
Marcel Burkett's Avatar
Originally Posted by RETed
In what way?
-Ted
Both the primary and secondary ports are larger in cross section on the Cosmo than on the REW , I am having my REW ports opened up to the Cosmos' size as we speak. The Cosmo produces more mower and torque at a lower boost and RPM than the REW .
Old Jan 10, 2005 | 06:21 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I have an RE and am running a to4s, no opionns on it so far though, finnaly started the car today for the first time. Should be on the road at the end of the week
-Jacob
Old Jan 10, 2005 | 06:38 PM
GOTBANNED?'s Avatar
Boost Addict
well looks like someone already took my answear,,i could not get one to respond..ohwell u have your answear..but this still does not decide on what turbo u should run..
Old Jan 11, 2005 | 01:53 AM
chris-reedtn's Avatar
im gonna be running my RE with a t66 when ever i get it put together.
-Chris
Old Jan 11, 2005 | 04:45 AM
There are simmilar threads to this one throughout the forum. I recall reading 2 or 3 where a stock ported RE was able to muster 390ish to the ground on a t04s. So im hoping for around there. Do a search in the single turbo and rotary preformance sections. More information there than you think
Old Jan 11, 2005 | 06:28 PM
i have a to4s i bought to use on my s5 motor. im selling it to go bigger. anyone have a t78 or 88, gt 40????
Old Jan 11, 2005 | 07:53 PM
setzep's Avatar
I have a TD07-25G on my stock port 13b-re. I'm guessing ~350rwhp at 15psi. The spool is very fast, I wish I had a bit larger turbine housing to try.
Old Jan 11, 2005 | 08:10 PM
rx7tt95's Avatar
Photo Diety
I'm using a GT4082 on a ported Cosmo 13B with FD exhaust sleeves. Full boost just after 4K rpm rolling into the throttle from low rpm. Made 406rwhp and then 396 with Steve Kan tuning the second time. Great midrange/torque.
Old Jan 14, 2005 | 07:49 PM
anyone have pics of the motor in there car? I'd just like to see them. Thanks
Rodney
Old Jan 14, 2005 | 08:12 PM
SnowmanSteiner's Avatar
Ga-nome liberator
The Runners on the RE are also significantly larger than both the 13B-REW and the 13B-T. The exhaust ports are also signficantly smaller, to provide more low end torque since it was in a luxury car. Most people I know who run or have run them switch to either 13B-REW or 13B-T housings to allow greater exhaust flow. NOTA944 was running a 1/2 bridged 13B-RE with 13B-T housings. He was also running a GT40 not sure on the exact specs.
- Steiner
Old Jan 15, 2005 | 12:45 AM
- Steiner
The secondary runners on the 13b REW and the 13b Cosmo are the same , however the primaries on the Cosmos are larger.
Old Jan 15, 2005 | 09:57 AM
Lynn Bordes's Avatar
Mark White admirer
RE has 40mm
At the flange of the Upper Intake Manifold/LIM the REW bores are 35 & 38mm. The RE has 40mm on all four bores. One big difference is the nice large sweeping turn instead of the sharp 90 at the port.
Barry
Cosmo RE (Ito template) Street-port, Teflon/silicon combustion seals, 2-piece 2mm Mazda apex seals,TO4s, Magnacore wires, HKS cast divided Manifold, 50mm Wastegate, A'PEXi PFC, 550 & 1600 injectors, Supra Pump
PFS IC, Full 3" SS exhaust with RB Muffler. ACT Extreme pressure plate.
Old Jan 15, 2005 | 03:30 PM
Erdin's Avatar
Water Injection Specialist
Barry
What sort of power are you makeing mate
Old Jan 17, 2005 | 06:23 PM
Mark White admirer
No Datalogit
Erdin, I haven't had it tuned yet, need a datagogit ( backordered). Have been driving like my mom. Probably will have Steve Kan tune it if we can get him down to New Orleans. Will post if it's newsworthy.
Barry
Old Jan 18, 2005 | 05:34 PM
Erdin's Avatar
Barry
Thanks Barry, I look forward to it.
