Sponsored by: CARiD
idle problems need help
Old Jan 7, 2005 | 06:49 PM
chrisw80's Avatar
Talking idle problems need help
Hi
I have a 1987 rx7 turbo with a j-spec 13b turbo engine. I can not get the dam thing to idle at all i can start the car and it will start and idle @ 1500rmp's for a second or 2 and than drop down to like ~600rpm and than drops to 0 and trys to stay at 0 for a second or 2 and than dies. Its not a vacuum leak because i just replaced all my lines and there all fine as far as i know. And i just set my tps throttle position senosr to 1 ohm and adjusted my throttle adjustment screw and this is where i ended up and so i still cant get it to idle dose anyone know what i should do or what i should try. thanks
Old Jan 7, 2005 | 06:55 PM
DocMazda's Avatar
sounds like it could be your air flow meter. Do a voltage check on that thing just to make sure. also, check the basic stuff....fuel pump getting correct voltage as well? spark-plugs, etc....
Old Jan 30, 2005 | 07:02 PM
earthisflat's Avatar
somethings always wrong
i have the same problem, i just rev the engine up for alittle bit and then it doesn't die, it'll still idle, but i also have a street port, don't know if it makes that much of a difference......
Old Feb 2, 2005 | 03:25 AM
RE Suzuki's Avatar
I speak Japanglish
lol...u got a whole alot of problems with your car..
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
