Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Signal error count 7??
Old Jan 1, 2005 | 08:33 PM
Net Seven's Avatar
My car runs like **** for some reason and im getting the signal error count 7 popping on the laptop... Can someone tell me what that means?
Old Jan 1, 2005 | 08:45 PM
eViLRotor's Avatar
Brother of the Rotary
Every time you get a signal count error, it means the ECU is not getting a trigger signal. This means the ECU will not charge the coils or fire the injectors.
I had this problem quite a bit with my V3.
Usually the problem has something to do with the CAS/CAS wiring/trigger settings.
Make sure the magnetic pickups in the CAS are as close to the teeth as possible. Make sure your CAS harness is not routed near any power wires (like the main alternator wire).
Make sure you input filter settings are correct.
Old Jan 2, 2005 | 12:02 AM
Net Seven's Avatar
Somehow the polarity got switched from rising edge to falling edge making my car run shitty. Still doesnt run as good as yesterday.
Old Jan 3, 2005 | 02:42 PM
nyt's Avatar
nyt
lots of cars get noise on start. as long as youre fine when running/revving its nothing to worry about
Old Jan 3, 2005 | 05:26 PM
Net Seven's Avatar
I dont ever get noise and never did with my settings correct. After I found the polarity got switched and put it back to upstream, the car started right up and never got signals errors.
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Devon Murray
Sep 26, 2015 08:15 AM
