Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D how to use stock tach with wolf3d?
Old Jan 1, 2005 | 03:20 AM
Net Seven's Avatar
After I wired in the wolf my stock tach stopped working. Just wondering how I get it working again?
Old Jan 1, 2005 | 03:58 AM
nyt's Avatar
nyt
tach gets its feed from the coil. it shouldnt have stopped working unless you disconnected some factory wiring. if you want it to work again just splice into the signal wire and run it to the tach where it is supposed to go
Old Jan 1, 2005 | 04:28 AM
Net Seven's Avatar
Well im not running the trailing coils right now so that might be why. Is it fed off the trailing or the leading coils?
Old Jan 1, 2005 | 12:18 PM
Chris Ng's Avatar
I'm with stupid -----^
trailing
Old Jan 1, 2005 | 06:36 PM
the stock setup in fc's uses a switch in the trailing coil pack, so the tach wire sees both signals. If you are running a custom setup (not using the stock trailing coilpack) you will need to take your reference off of a leading coil, which will see the correct amount of signals. (if you wire to your trailing, your stock tach will read half of the rpms that your motor is actually running at)
Old Jan 2, 2005 | 01:25 PM
Net Seven's Avatar
So once I get my trailing coils working with the bosch dual channel igniter, then my tach should start working?
Old Jan 2, 2005 | 07:42 PM
if you run the tach wire to one of the trailing coils (assuming your using two now) then your tach will read half the rpms that the engine is turning.
Old Jan 2, 2005 | 08:23 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
If you hook the tac up to both channels of the ignitor it will
Where are you ordering your ignitor?
Old Jan 3, 2005 | 02:37 PM
nyt's Avatar
nyt
If i remember correctly, since im not using stock igniters, I ran the wolf tach output to the blue(i think??) tach test wire off the trailing coilpack.
streetlegal?
Mar 17, 2022 02:46 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
Coolant_Leak
Aug 30, 2015 11:18 AM
