AN fitting question
Old Dec 29, 2004 | 06:04 PM
Sesshoumaru's Avatar
Tenseiga
AN fitting question
I'll be running a -3 AN feed line on a to4e.
My question is what fitting/size/thread pitch do I need in order to use the stock oil feed line or to plumb directly into the block (where the banjo bolt normally goes)
I saw someone use the hard line on the s6 and i think they are identical as the s4/5.
As for the drain i'm using the stock pipe and I need a hose that can go over that. Would a -12AN be big enough to go over the outer diameter of the stock pipe (from front cover)?
Old Dec 29, 2004 | 06:20 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
https://www.rx7club.com/showthread.p...il+feed+thread
Old Dec 29, 2004 | 06:58 PM
Tenseiga
thnx
rx7ali
Dec 12, 2015 06:00 PM
ptuttle
Aug 27, 2015 07:03 PM
