? on horse power on stock internals
Old Dec 26, 2004 | 11:59 AM
10thanniversaryrx7's Avatar
Question ? on horse power on stock internals
Well I'm in the process of getting ready to build my 7 and I am trying to find out what kind horse power the stock internals will handle so I know if I need to go with a rebuild with street port and 3mm seals first or if i can get what i want out of the stock internals. Any info will help. I did search and found nothing that would help me out. Thanks in advance.
Old Dec 26, 2004 | 12:46 PM
Windsor, Ont
alot of people swear that the stock 2mm seals are better than 3mm..
There is nothing really you can change internally besides the seals unless you have heaps of cash for lightend rotors, ect... Performance mostley depends on what you do to the other things like porting and boost.
but dont believe what I say.. let's hear someone who actoually has experience with this.
Old Dec 26, 2004 | 12:55 PM
RotaryEvolution's Avatar
Sharp Claws
the stock internals are good, i would say an n/a internals can handle upwards of 300RWHP easily but not so easy to get that high with an n/a unless bridgeport it. turbo internals are good up to and beyond 350RWHP.
stick with 2MM seals unless your rotors are worn out and won't fit stock 2MM seals anymore.
Old Dec 27, 2004 | 05:18 AM
RETed's Avatar
Control detonation and 500hp is not surprising...
-Ted
Old Dec 27, 2004 | 10:40 AM
Aaron Cake's Avatar
Engine, Not Motor
You do realise that NA and TII "internals" are exactly the same except for compression?
Up to 400HP on each engine, and then you start looking at doweling.
Old Dec 27, 2004 | 04:55 PM
rodney87's Avatar
-Ted
isn't detonation a bad thing?
Old Dec 27, 2004 | 05:40 PM
RETed's Avatar
YES!
Detonation on an engine "only" producing about 270hp will CRACK oil filter bases (non-reinforces Zenki engines) and the opposite oil supply port on 13BT turbo engines.
-Ted
Old Dec 28, 2004 | 02:20 AM
NZConvertible's Avatar
I'm a boost creep...
Yes it certainly is. What Ted meant by "controlling" detonation is not having any!
Old Dec 28, 2004 | 08:29 PM
Sharp Claws
i was told T2s had hardened gears where N/As weren't hardened. ah well, just passing on my own misinformation...
Old Dec 28, 2004 | 08:32 PM
damn guys so it wouldn't be hard to get 400 whp out of my stock TII motor the just got to control detantion. Sounds good to me.
Old Dec 28, 2004 | 09:29 PM
RETed's Avatar
Yes and no.
Both Kouki turbo and NA engines are "ion-nitrided" stat gears.
The Kouki turbo rotors gears are ion-nitrided also; the Kouki NA rotor gears are not.
-Ted
Old Dec 28, 2004 | 09:30 PM
Pinfield357's Avatar
no one said that it wouldnt be hard we are just telling you it can be done
Old Dec 28, 2004 | 09:58 PM
Sharp Claws
just depends on how fat your wallet is, it could be easily done if you got the $.
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
