broken clutch or more?
Old Dec 24, 2004 | 05:40 PM
rx7whore's Avatar
okay i have a turbo II
any ways, i was driving and my clutch pedal got stuck to the floor and a chafing noise came from the front of the tranny, then it wouldn't even go into gear...
i checked the the clutch master cylinder and the slave along with the lines, they look good. but the car won't go into gear
so do u think i broke the pressure plate or could it be something else?
Old Dec 24, 2004 | 10:31 PM
Turbonut's Avatar
Check fluid level. You can try to bleed the system, but chances are you'll need new parts, or you can rebuild the master cyl/slave cyl.
Old Dec 24, 2004 | 10:34 PM
Parastie's Avatar
Mountain Rotary Mod
I'm with Turbo, it sounds like the cylinders, no the clutch or clutch parts.
Old Dec 24, 2004 | 10:51 PM
therotaryrocket's Avatar
PIMP
my friends 87 base did something similar, it wouldn't go into gear at all unless we turn off the engine put it in gear then restart it. Well his car finally stopped doing that but he still gets some crazy noises like squeaks with the clutch pedal down and chafing as you mentioned, but worse the car clunks and the clutch only engages on like the first 2" from the floor. I think it is because of misalignment between the engine and transmission or something with the pilot bearing. Maybe the clutch release bearing (throwout bearing) is jammed up on the input shaft of the flywheel?!?!?? just some ideas.
Old Dec 24, 2004 | 10:58 PM
RotaryEvolution's Avatar
Sharp Claws
^ tell your friend to flush out his clutch fluid and bleed the system throughly, then adjust the clutch rod as per the FSM. his master may be going out but adjusting the rod may give him a little extra time before it finally does let go.
Old Dec 25, 2004 | 08:08 AM
Therx7ist's Avatar
In your original post, you stated that master, slave and lines look ok. @ months ago, I had the exact same problem. Assuming you are correct about the state of the hydraulic system, I would start by checking the inspection areas of the tranny. Look up from underneath car and look at flywheel. Is the flywheel and clutch still intact? Most likely it will be. If everything looks ok from under there, get ready to drop your tranny. The culprit in my case was the small pivot bolt on the back of the inside of the bell housing. This is the pivot point for the fork which moves your throwout bearing. Mine had snapped off, leaving me with no control of the fork and therefore the pressure plate. It's not too big a problem if your used to doing rx7 trannies. Good Luck
Old Dec 25, 2004 | 10:05 AM
PIMP
thanks karack, my friends hydraulic fluid looks really black too, we can flush the fluid.
Old Dec 25, 2004 | 10:47 PM
rx7whore's Avatar
thanks, i'm gonna look @ it when i get back to my tech skool, i just been so busy that i haven't been able to look @ it, much yet work on it
dave
risingsunroof82
Sep 9, 2015 08:06 PM
