You know you're a 1st gen owner when...
on
You lift weights to make low speed steering easier
You tune a little rich on purpose just to shoot bigger flames
You try different methods of backfiring to see how loud you can get
You're the reason the local parts shop stocks MMO
Any others?
Any others?
The following users liked this post:
Gearheadlevi (03-28-20)
nother rican witha rotary
on
Originally Posted by hiboost7
when you can sprint to 60' faster than your ride...your a first gen owner
Originally Posted by numan2
your used to crwaling through the passengers side because the drivers door handle is broken.
Favorites:
When your RX-7 actually runs.
You don't hesitate to drive it anywhere, anytime.
You can fill up your RX-7 with "regular" grade fuel.
*What about either having/not having Malloy Mazda on speed dial?
Trending Topics
You know you're a first gen owner when somebody says, "This your car?"..."How many do you have?".
You can fail emissions with stock equipment, strip it all off and pass.
You see another first gen, start waving like crazy, and realize it's a Datsun.
Low Budget Modder
on
This is more like a "You know your an rx7 owner" thing but
You know your an rx7 owner if; someone comes up to you and says "Nice car! What kind of engine does it have? (before you get to reply) 4 cylinder? 6? 8?"
Darth Suppah
on
... you realise the rear hatch glass is worth more then you paid for the car.
... you purchase two parts cars just so you can be sure to have the right part at the right time.
... you contemplate turning your cold start assist system into an MMO injection system.
... you consider FC's and FD's "Bloated Pigs that handle like a brick"
... you could actually pull the stunt from TF&TF when they drive under the semi trailer *puts on flame suit*
... you check underneat the front end every day to make sure the stain didn't change colours.
... you consider changing anything and everything to electric to free up the engine a bit.
... you rape parts from FC's to make your FB run better. (oil filter pedistals, radiators, alternators, etc)
Southwind Seven
on
When you keep your 7 cleaner than your house.
When you pull up a lawn chair and admire your car while it's still in the garage.
When you park a mile away from the store entrance so no one bangs your doors.
When you say WTF! don't slam my door so hard!
When you love to see the look on peoples faces when you say it doesn't have pistons.
