Oil pressure regulator questions/upgrades
Old Dec 6, 2004 | 11:46 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
I was wondering if anyone knows the stock oil press reg pressure? According to the FD FSM, the stock relief is 110 psi. Racing beat sells a 130 psi race only regulator for $90.00. my question is, is the FD one an upgrade? if not how would the RB 130 psi one work for occasional street use but mostly track use? 2nd part, i am using s5 gauges in my fc, but i was gonna use an FD oil pressure sender./ will it read correctly or are the voltages different? thanks!
Old Dec 7, 2004 | 03:05 PM
Merovingeon
Veteran: Air Force
come on now! 16 people and no one knows? hmmm
Old Dec 17, 2004 | 06:46 PM
Merovingeon
Veteran: Air Force
the FD oil press sender wont work with fc gauges....FYI
Old Dec 20, 2004 | 01:42 AM
diabolical1's Avatar
according to Racing Beat, you'd have the shim the front regulator 1/8 inch and a hardened pump is recommended.
Old Dec 20, 2004 | 07:44 PM
Merovingeon
Veteran: Air Force
yea, the shims come with their regulators...but whats this about a hardened pump?
Old Dec 20, 2004 | 08:19 PM
if i undertsood it, they essentially said that if you don't use a hardened pump (Mazda Factory Race) with sustained pressures over 100 PSI, then the stock pump will kill itself maintaining such a high pressure.
Old Dec 21, 2004 | 02:49 PM
Merovingeon
Veteran: Air Force
woa..I guess I need to find a hardened pump then. Since FD uses 110PSI regulator, is that pump hardened?
Old Dec 22, 2004 | 10:21 PM
not sure , but since it was designed to run at that pressure it's probably safe. question: aren't the 13B-REW front housings the same as the 20B? it should use the same pump, no?
Old Dec 23, 2004 | 09:30 AM
Merovingeon
Veteran: Air Force
I havent compared them side to side. It was my understanding that the 20B used alot of the FC parts. It uses FC CAS, oil pressure regulator and rotors
Old Dec 23, 2004 | 11:12 AM
well i don't know enough about the intimate details of the 20B to speak intelligently on them being more akin to the 13B-T as opposed to the -REW, so hopefully someone else that knows will step in and settle this for you.
maybe you could try to PM Jeff20B or Evil Aviator (on this board) with your question. i know they have more 20B knowledge than i can offer ...
sorry , but i'll stay posted
Old Dec 23, 2004 | 02:03 PM
Jeff20B's Avatar
Lapping = Fapping
The 20B has lots of S5 goodies. Evil A will probably have plenty of links to help answer your questions.
Old Dec 23, 2004 | 09:24 PM
Evil Aviator's Avatar
Rotorhead
Thanks guys, but this is a question for a mechanic. These are not issues with my 20B project, so I don't know anything about them.
BTW, aren't the shims only for the really old rotary engines?
Old Dec 23, 2004 | 10:57 PM
Merovingeon
Veteran: Air Force
yea, ive been checkin on his links. lots of good stuff in there. also, after a lil research, the FD and S5 turbo use the same oil pump dimensions; 50 X 17.5mm
Snoopy FD
Dec 8, 2015 01:45 PM
