Proof is in the Paper !!
Old Dec 1, 2004 | 05:01 PM
rob20rx7's Avatar
Injected with a Poison
Here is the Pic. shows my Dyno Run from Friday.
492 RWHP @23Lb Boost 393 Torque
Might i add on Pump Gas 93 Octane and Alcohol Injection
http://img.photobucket.com/albums/v...20Sheets/11.jpg
Old Dec 1, 2004 | 05:03 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Linky no worky and I don't see a pic either.
Old Dec 1, 2004 | 05:04 PM
rob20rx7's Avatar
Sorry, Try this
http://img.photobucket.com/albums/v2...0Sheets/11.jpg
Old Dec 1, 2004 | 05:08 PM
silver93's Avatar
damn, man - that's nice!
Old Dec 1, 2004 | 05:09 PM
KaiFD3S's Avatar
SINFUL7
nice...who tuned your car...your a/f ratios is nice and consistent
Old Dec 1, 2004 | 05:13 PM
Hm, #s look good, but a couple of things.....why start the pull at such a high rpm? Also, your a/f's are looking kinda 12ish for much of the pull. Too lean for my tastes, although i am sure the injection helps....is this a 50/50 mix of methanol and water, or straight up methanol?
492 to the ground on pump gas is unheard of for a 13b......how close to 'the edge' are you tuned I wonder? Make sure that tank is never on empty
Old Dec 1, 2004 | 05:17 PM
RotorJoe's Avatar
I’m curious about this too.
Old Dec 1, 2004 | 05:23 PM
the_glass_man's Avatar
Will u do me a kindness?
500 rwhp on pump gas, nice!
Old Dec 1, 2004 | 05:25 PM
Talking
That's all you have to say, Mr. Dearborn?
c00lduke's Avatar
Also, what injection kit do you use?
Old Dec 1, 2004 | 05:36 PM
rynberg's Avatar
hmmm..."Standard" ratings instead of "SAE".
Does that turbo really not spool until 4500 rpm or is that just when the dyno run started? Nice flat powerband once it (finally) hits.
Old Dec 1, 2004 | 05:42 PM
scotty305's Avatar
~17 MPG
Yes, more info on the alcohol injection please...
Also, what ignition setup are you running?
-s-
Old Dec 1, 2004 | 05:45 PM
SPOautos's Avatar
Hey, where did my $$$ go?
What turbo are you running? It just says TO4R...what compressor wheel is in it?
Old Dec 1, 2004 | 06:07 PM
Boostn7's Avatar
Nice numbers Rob....500rwh !!! simply awesome :-)
500rwh is also my goal on pump gas.... car should be on the dyno soon...as soon I have time.
Congrats again,
JD
Old Dec 1, 2004 | 07:35 PM
Congrats again,
JD
JD, I neeeeed some tuning man! Boost creep is killing me in this cold weather, and I can't rev past 6k . Been trying to get in touch with you for a long while now......bryan at BNR should have mentioned me. Please get in touch with me via PM
Rich
Old Dec 1, 2004 | 08:21 PM
Boostn7's Avatar
Rich...you have been PM'ed :-)
JD
Old Dec 1, 2004 | 09:28 PM
JD
I am forever grateful
Old Dec 1, 2004 | 10:27 PM
the ancient words's Avatar
that whiplash powerband must be uncontrollable anywhere but the drag strip
nice #s tho
Old Dec 2, 2004 | 04:31 AM
t-von's Avatar
Rotor Head Extreme
nice #s tho
Yea tell me about it! Look at the how much the torque jumps between 4k-5k rpm's. It goes from less than 150lbs up to around 360lbs in 1k rpms.
Do you have anything to measure knock with the alcohol injection with those A/F ratio readings? Seeing a graph like this gives me more confidence about how well our engines are capable of running in a well tuned & well set-up condition.
Old Dec 2, 2004 | 08:31 AM
neit_jnf's Avatar
Old Dec 3, 2004 | 05:56 PM
RotorJoe's Avatar
-s-
That makes four of us. Come on dude get back to us.
Old Dec 3, 2004 | 11:02 PM
damn, check out the quoting skillzzz you exhibit. Homeboy should reply just outta respect for all the work you went through
Old Dec 6, 2004 | 07:51 PM
Gargamel's Avatar
what's the deal here?
Old Dec 6, 2004 | 08:13 PM
As in what's the big deal this guy is making 500 rwhp on pump gas?
or
What's the big deal with him not giving anymore info regarding his injection setup?
A) It's a secret family recipe. Much like Bucsh's Baked Beans, the only way we are ever going to find out is if his dog breaks down and tells us. This is assuming he told his dog in the first place and/or he even has a dog.
B) He doesn't know what's in it. He just throws in some Arby's Secret Special Sauce with a mix of Taco Bell Hot. Since the sauce is a closely gaurded secret we may never real know and he's not telling.
C) He likes getting us all worked up and will someday reply to this thread.
D) Aliens have beemed him back to the mothership and forbid him to speak further on his injection setup
E)All of the above
Old Dec 7, 2004 | 05:28 AM
Gargamel's Avatar
or
E)All of the above
what is "B"?
