Best options for single turbo upgrade...
Hey guys, I currently drive an Audi S4 and am selling it shortly to purchase a FD. I want to build a reliable motor and single turbo it shortly after I get it, or is it safe to run a single turbo on a stock motor? I am kind of a RX7 noob so I am looking into how much it will cost for building the motor up, buying, installing and tuning a single turbo kit and everything that I should look into getting when I do this. I am not too concerned with lag so that is no problem, it is primarily going to be a street car so no slicks or anything like that. I am basically trying to figure out the best kit and prices that I should be ready to pay for everything to be done safely and correctly. Any links would be great.
Also, is there any shops I can talk to in the New England area that could help me with this. Thanks.
Adam
Adam
Gunzy are you willing to trade your S4? I have a 95' us spec car with a street ported 3mm hurley apex seals with a single gt35/40. I'm orginally from New Bedford,MA but currently in Greece. PM me or email me at dznutzuk@yahoo.com if you are interested.
Adam, you need to upgrade the fuel system, the engine management, and usually the ignition system to go single. You CAN do it on a stock engine block if you like, but many people port the engine to get that last bit of "oomph".
Here's how much it cost me to go single doing all my own labor:
http://www.zeroglabs.com/rx7/mods.htm
http://www.zeroglabs.com/rx7/newturbo.htm
http://www.zeroglabs.com/rx7/images/...2604.14psi.jpg
Anyhow, the result is pleny of power on the street!
Trending Topics
stock motors run fine with a single turbo. I would also say likely to be more reliable for pump gas and conservative boost. Too many things can go wrong with a ported motor. Alot of error involved. IF your starting out a stock motor with a decent turbo would be ideal. Less money also. I ran a single turbo on my stock motor for a while. 400 hp is easy on pump gas with the right turbo.
I used to live in NH and have seen your car a few times on NH101.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
