what carbs are you guys runnin'
Old Nov 19, 2004 | 09:21 AM
Matt22's Avatar
Fear The RE
as it says what carbs are you guys runnin on your old schoolers?
I need to learn more about carbs and what means what, what is right for what setup. all the basics, so here i am trying to learn.
thanks I think i will also get a book. lates matt22
Old Nov 19, 2004 | 09:26 AM
Siraniko's Avatar
RX for fun
48 Ida
Old Nov 19, 2004 | 10:39 AM
Matt22's Avatar
Fear The RE
whats that mean? i really have no idea.
Old Nov 19, 2004 | 11:09 AM
Superrican's Avatar
Rican Engineering
its the model of the carb , The brand name is webber , and 48 ida is one of the models theres a bunch more of webbers , you should search for webber carb direct ( i think thats the site ) Webber has sidedraft carbs , (which means the carb is sideways/ horizonal ) , downdraft wich i guess it sticks down , Dellororto is basically the same kind of , Just different brand name and THen Holley ,
Old Nov 19, 2004 | 11:21 AM
Superrican's Avatar
Rican Engineering
i have a 600 holley , Holleys ok , Well at least i think so , but around where i live all the rotary guys that decide to go Carb , have holley , i see holley carbs usually on the Drag strip , so if your gonna drag race then i guess use holley , But all the AutoCross an Road race events that i go to an see rotary cars usually have Webbers OR dellorto's , sooooo i guess if your gonna drag then use holley , if your gonna road race go webber ,
Old Nov 19, 2004 | 01:31 PM
FB II's Avatar
weber is the jam
Old Nov 19, 2004 | 03:19 PM
Crit's Avatar
No distributor? No thanks
I run a Weber 51 IDA. That's a downdraft 2-barrel. The Dellorto DHLA is a sidedraft 2-barrel that has less power, better streetability and a choke. Then there's the Holley, Nikki and Hitachi 4-barrel normal-lookin carbs. There's also the occasional Mikuni sidedraft as well. A Dellorto DHLA 48 has a 48-mm main venturi. Holleys and such are measured in terms of cfm, Weber, Mikuni and Dellorto are typically described by throat size (40, 44, 48, 51 mm). Are you looking for pics, or what?
Old Nov 19, 2004 | 03:56 PM
Hullie's Avatar
My Deuce Coupe
I have a Hitachi 4Bbl w/ Mechanical Secondaries.It seems to run good ....My only bitch is it doesn't have a Choke hooked up So I have to sit in the car w/ My foot on the gas til it idles usually about 7-10 Min.
Old Nov 19, 2004 | 04:29 PM
Matt22's Avatar
Fear The RE
pics are nice if they are handy, but no worries.
So if i was gonna use my car for daily driving and some autocross i should probably go with a Dellorto cause it would be more streetable. I would also spend more money on one thats easier to tune. I read that the webbers are easy to tune. how do you guys feel about that? Thanks for all your replys by the way. Matt22
Old Nov 19, 2004 | 07:26 PM
Crit's Avatar
You can find a link to my Dellorto setup for sale in my sig. Webers are more simple and make for generally better race carbs. Dellortos are more streetable because they have a longer progression region (part-throttle response) and a choke. Dellortos are unique in that you can even swap jets with the car running. You don't have to open the carb up to change jets. Webers have a larger selection of jets, but they're equal in terms of how easy it is to tune. Dellorto parts are harder to track down, as well, so getting a few spares is a good idea if you go with one.
Dellorto:
https://www.rx7club.com/showthread.p...light=dellorto
Weber:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33550
Holley:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Mikuni:
http://rx7.voodoobox.net/howto/racecar/racecar.html
Old Nov 19, 2004 | 08:10 PM
Superrican's Avatar
Rican Engineering
ya , buy webbers or dellortos , Holleys to much of a problem ........Also when you pop your hood i would rather see some pretty Webber rather than a holley lol anyday .......
Old Nov 19, 2004 | 08:56 PM
Crit's Avatar
Very true. Webers, Dellortos and Mikunis just look like works of art. I always thought so too...
Old Nov 19, 2004 | 09:48 PM
680RWHP12A's Avatar
weber is all i sell!!
Old Nov 19, 2004 | 10:49 PM
Matt22's Avatar
Fear The RE
so Crit what do you need for your RX2, that you would consider partial trade, for your old setup. even though i wold have to buy the 12a intake pieces but still evenutually might go to the 13b. let me kwow. matt22
Old Nov 28, 2004 | 06:32 PM
88t2romad's Avatar
(_8(|)
i got a weber ida 48 on my 87 rx7, and i love it, runs great
Old Nov 28, 2004 | 10:15 PM
rxtasy3's Avatar
holley 600cfm setup from rb on my sp 13b.
Old Nov 29, 2004 | 08:16 AM
Siraniko's Avatar
RX for fun
Im going P-Port in my RX-3. I will be trying out a GENE BERG 55 IDA style carb. I wanna see if this will work better than my old 51.
Tylerx7fb
39
May 27, 2019 12:45 PM
Jun 26, 2016 10:21 AM
Clacor
Aug 14, 2015 09:17 AM
