just a few diff. questions
Old Dec 5, 2001 | 03:40 AM
easy p-cheesy's Avatar
SPORKY
first off... is the rear suspension independant? (if equal weight is on both wheels, will they both leave rubber on the ground?)
is there a visual difference between LSD units and open diff.? I can't just go out and jack the tires up and spin the wheel to check. I've got messed up brakes so I can't get the wheels spinning, only move them a bit.
Old Dec 5, 2001 | 05:34 AM
Cwaters's Avatar
Just Messing About
My 86 GXL had a tag around the filler bolt (or was it the drain bolt?) that said to only use a LSG lube in there. The tag was really gunked up, of course, but it was easy to clean and read.
If it's there, good bet it's an LSD. If not, you'll have to figure it out on your own.
Old Dec 5, 2001 | 05:36 AM
Cwaters's Avatar
Just Messing About
Oh,
I have two rubber stripes on the floor of my garage from my 7. That's from leaving, mind you, not panic breaking
Cory
Old Dec 5, 2001 | 11:26 AM
vaughnc's Avatar
knowledge junkie
Cwaters,
Or when your friend always parks it in 1st gear and you don't.
I HATE that - scares the crap out of you when you let off the clutch.
Old Dec 5, 2001 | 11:59 AM
Icemark's Avatar
Re: just a few diff. questions
Both the front and rear suspensions are independent. The angle of one does not effect the reaction of another.
If you had a LSD, that was engaging perfect, and the weight of the car was perfectly distributed over both sides and tires (including composition, air pressure, temperature, radius, and diameter) were the same then yes in theory you should be able to leave two perfectly equal tire burn outs.
Old Dec 5, 2001 | 02:14 PM
SPORKY
AAAAAAAHHHHH!!!! I was afraid of that. now do I fix the brakes or not...
Old Dec 5, 2001 | 03:39 PM
Icemark's Avatar
Always fix the brakes first.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
