Red hot pipes
Old Nov 14, 2004 | 09:51 PM
impactwrench's Avatar
Red hot pipes
I recently bought a single turbo kit from a seller on ebay. Nothing fit right but luckily, I have access to a machine shop. I started it up tonite to check for oil leaks and such,and found that after about a 10 minute warm-up, the exhaust manifold from the block to the turbo is red hot. I mean when you idle up, its real red. Is this normal? If it is, should I wrap it with insulation, or what?
Old Nov 14, 2004 | 10:23 PM
Gregs's Avatar
that wouldnt be the turbos fault, thats generally a sign that you are running lean, adjust your AF mixture
Old Nov 14, 2004 | 10:25 PM
Gregs's Avatar
oh and which kit did you buy, got a link? if its the one i think it is, was it like 499 for everything?
