turbo spin at idle...?
Old Nov 5, 2004 | 08:39 PM
93FD3S's Avatar
Big Snail
In my FD I'm running a single turbo setup on my new street ported motor. What I noticed is that when the car is idle especially when the engine is cold the compressor wheel doesn't spin very much at all. I checked for oil leaking, no leaks, and hardly any shaft play, spins pretty freely when I spin it with my hand. When I rev the motor slightly it spins. Its a brand new turbo. Its not a very big turbo. .70 compressor and .96 hot side P-trim. Question is that normal? Thanks..
Old Nov 5, 2004 | 09:02 PM
RETed's Avatar
What kinda oil do you use?
What is the ambient temps?
-Ted
Old Nov 5, 2004 | 09:07 PM
93FD3S's Avatar
Big Snail
I'm using Castrol 20-50 non synthetic for break in on new motor temp right now is about 60-65 degrees F.
Old Nov 6, 2004 | 12:05 AM
RETed's Avatar
Hmmm, not overly thick or overly cold...
I'd keep an eye on boost once the engine is broken in.
-Ted
Old Nov 6, 2004 | 03:21 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
what I noticed with my new setup (included a brand new turbo) is that the turbo did not really spin that fast untill I had driven the car for a few hours.
after that it seamed to spin up much faster than at first.
weather or not the oil is up to temp seamed to have an effect on the turbo spinning as well.
Im running a stock s5 TII motor and a 60trim/1.15 divided P-trim and now it spins fast at idle.
Its probably just the new seals and everything breaking in.
Old Nov 6, 2004 | 09:01 PM
93FD3S's Avatar
Big Snail
I hope its because the turbo is new. I've only put about 5 mls on the new motor and turbo. So we'll see. Thanks..
Old Nov 13, 2004 | 10:51 AM
Marcel Burkett's Avatar
I had abrand new turbo on my motor and it spun so fast you couldn't actually see the individual fins !!! , lots of air would blow out of the discharge too ! , what rpm does your car idle at ??.
Old Nov 13, 2004 | 06:47 PM
93FD3S's Avatar
Big Snail
Actually the Turbo is now spinning pretty fast even at idle. I've put about 60 miles on the new motor and turbo. Maybe it just needed a break in. My car idles at about 800rpms. So far so good. Thanks.
Old Nov 15, 2004 | 07:52 AM
rx7raca's Avatar
wHiTe kNiGhT
If anything, I would say that the reason is because the motor doesn't have a stronge compression so it doesn't have alot of flow. The other is that the turbo is not broken in so the bearings aren't to loose yet.
Old Nov 15, 2004 | 09:45 AM
93FD3S's Avatar
Big Snail
Yea I figured it was because the turbo was new. I also figure the compression will get better on the motor futher along in the break in on the new motor. Tony
Old Nov 15, 2004 | 08:02 PM
gxlspeeder's Avatar
It should spin alot more once its broken in. The bushing are still getting seated.
Queppa
Nov 18, 2024 03:47 AM
C. Ludwig
Jan 30, 2019 06:31 AM
PhillyFC
Aug 21, 2015 06:36 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
