Sponsored by: CARiD
engine rebuilt problems
Old Oct 23, 2004 | 11:47 PM
rx-7fc's Avatar
i had my engine rebuilt and got about 1300miles on it and it blew up i had i think 2-3 apex seals broken in the rear and and 1-2 cracked. the housings were messed up on the sides the front was only a little and only one rotor was messed up.the apex seals were broken on the sides my engine builder said that i detonated but i don't think so i wanted to make if any other kind of thing would make that happen this was on a turbo2
Old Oct 24, 2004 | 02:57 AM
RETed's Avatar
Improperly built motor.
Overheat.
Overrevved.
Improper break-in.
-Ted
Old Oct 25, 2004 | 12:51 AM
RotaryEvolution's Avatar
Sharp Claws
you don't think improperly tuned should be in there?
Old Oct 25, 2004 | 01:23 AM
RETed's Avatar
Sure, but I'm assuming it's stock.
-Ted
Old Oct 25, 2004 | 03:22 AM
Mr rx-7 tt's Avatar
rotary sensei
Detonation
Maybe overheated
Did they mill the rotors? I have seen improperly milled rotors do this.
Old Nov 18, 2004 | 05:30 PM
rx-7fc's Avatar
it was not overheated or overreved.i think may be the guy that built my engine or detonation.it was stock with 2mm 2 peice seals and a s5 turbo with full racingbeat exhaust and knightsport fcd. i am going to build it again but i need one rotor i have one s4 and one s5 so i need to look for one of them and buy new seals. i was boosting like 8-10 when it was running or could have that made it run lean.
Old Nov 18, 2004 | 10:39 PM
RETed's Avatar
Boosting when it was cold at night???
-Ted
Old Nov 20, 2004 | 12:45 AM
Bamont's Avatar
Billy Bo Jangles
Having a lean mix could have definitely caused detonation.
Old Nov 22, 2004 | 06:36 PM
rx-7fc's Avatar
it was in the day time
Old Dec 12, 2004 | 08:31 PM
rx7will's Avatar
check you pm and your voice mail.
Th0m4s
Feb 26, 2019 02:04 AM
Ciclovnz
Oct 18, 2015 03:04 PM
ncds_fc
Aug 15, 2015 10:06 AM
