Fluctuating Idle When Cold
Old Nov 30, 2001 | 01:39 AM
rico05's Avatar
WTB S5 N/A FC
Question Fluctuating Idle When Cold
My idle fluctuates between 1300 RPM and 1500 RPM until the temp gauge reads halfway between H and C (i.e. normal operating temp). Then when warm it holds an idle at 1000 RPM. If I screw the idle mix screw in, it will stop fluctuating when cold, but won't idle for s%$t when it is warm (i.e. at 200 RPM!!!!!!) WTF?
Old Nov 30, 2001 | 07:59 AM
go_speed_go's Avatar
What year is your car?
Old Nov 30, 2001 | 08:56 AM
Suparslinc's Avatar
It's Back!
got same problem on my '90 gxl. i think its the thermowax. any write-ups on how to fix it?
Old Nov 30, 2001 | 09:07 AM
SPEEDYRX-7's Avatar
my 90 gxl does the same thing pretty much. it has always started up fine for me and the rpms jump up when the engine is cold, and that part is normal. Then after the car is warmed up and i am driving it i stop with the clutch in and all and the rpms go down to like 600 or so and it kind of slowly bounces up and down from 600 to 900. Sometimes though the idle is around 1000 rpms. without the lights on or any electrical stuff the car seems to have a higher idle, but i am kind of concerned my idle is too low because with the lights on and stuff the car seems to idle too low.
Old Nov 30, 2001 | 09:29 AM
Suparslinc's Avatar
It's Back!
I heard this is a sure sign of a bad alternator; but I'm not sure if I agree with that. The low idle might be caused by your throttle position sensor; once I adjusted that it seemed to level off some when the car warmed up. But I'm almost positive the warmup fluctuations are caused by the thermowax.
mikedscpt
22
Oct 28, 2015 03:04 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
Monsterbox
Sep 11, 2015 03:29 PM
The1Sun
Sep 7, 2015 10:21 PM
vmerino
Sep 5, 2015 11:26 AM
