Need advice ASAP!
Old Nov 29, 2001 | 12:57 PM
Want2race's Avatar
Bigger and better things
Need advice ASAP!
I installed my highflow cat yesterday..
Well I cut off the stock air supply tube and welded it to the cat.
the problem is I did a half assed job and when i installed it It leaks air from the tube,
While I am pumping the darn air it better go into the cat to save the enviroment!
So my ? is:
Can I use JB weld to fill the small holes in the air supply tube??
TIA
Jonathan
Old Nov 29, 2001 | 01:08 PM
Flybye's Avatar
It's never fast enough...
It depends where the holes are at.
If it is too close to the cat, the JB weld will not work.
The intense heat will prevent it from staying on for long.
Old Nov 29, 2001 | 01:10 PM
Want2race's Avatar
Its is 1" from the cat. Its on the little stub like thing that was blocked off!
Old Nov 29, 2001 | 01:18 PM
Flybye's Avatar
Try it. You aren't going to kill or damage anything by doing so, and if it doesn't work, then just bring the cat down, like you would have had to, and weld another longer pipe to it.
Come on. Don't be a
Andrew7dg
Aug 6, 2017 01:41 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
risingsunroof82
Sep 7, 2015 01:11 PM
