simple air pump question
Old Nov 28, 2001 | 05:01 PM
shadyteke's Avatar
I want to lose some weight and clean up my engine bay. In my area there is no smog nor emmision inspections. Is it alright to remove the air pump? From what I know about it all it seems to do is feed air to the cats for emmision purposes right?
Old Nov 28, 2001 | 05:31 PM
UniqueTII's Avatar
Slow and old
On some N/As it opens the 6 ports...if you have a turbo, you'll be okay, but you'll need an acv blockoff plate too. They can be found at www.mazdatrix.com
Old Nov 28, 2001 | 05:38 PM
shadyteke's Avatar
yeah I have a tII. Will it cause any sorts of problems?
Old Nov 28, 2001 | 05:59 PM
smith88's Avatar
I have been thinking of doing the same thing. I just took out my A/C pump, cooler, and everything else for A/C.
If I wanted to go straight pipes all the way through, the air pump wouldn't be needed anyway. Right??
Someone told me that taking off the air pump would blow up my mufflers. I thought that sounded a little weird if it is just for emissions and not pressure.
Old Nov 28, 2001 | 06:03 PM
shadyteke's Avatar
well from doing searches on the board about this I know that removing the air pump will cause the cats to clog up. I'm pretty sure this could cause ur car to run rich. Dont hold me to that though. Over all though, it seems to be the opinion of everyone that this shouldnt be done unless you dont have any cats.
Old Nov 28, 2001 | 06:21 PM
NCsublime's Avatar
Yeah, I agree. I wouldn't do it if you still have cats. Otherwise it shouldn't do any harm. On the 89-91 NAs, the air pump does aid in opening the 5th and 6th ports by providing the extra pressure (that the exhaust doesn't provide) to reach the 1.8lbs of pressure needed to open up the secondary (5th and 6th) ports.
Derek
Old Nov 28, 2001 | 07:09 PM
13BAce's Avatar
On a long vacation
Yes, don't do it unless you remove the converters. You'll ruin the main cat with no air pump.
Old Nov 29, 2001 | 12:58 AM
Rx7-88na's Avatar
Okay -- SO i dont have any cats, but how do I know if my air pump opens the 6 port actuators? i have a 89...???
Old Nov 29, 2001 | 03:24 AM
UniqueTII's Avatar
Slow and old
Derek
Old Nov 29, 2001 | 04:01 PM
Rx7-88na's Avatar
So -- If I dont have cats, and i want to remove the air pump what do i need to do to ensure opening of the 5th and 6th ports?
Also, what to do with the hose that was pumping air through my cat??
Thanks
Old Nov 30, 2001 | 01:36 AM
Rx7-88na's Avatar
No one knows? anyone with a 89 NA? damnit...
Old Nov 30, 2001 | 02:06 AM
hypntyz7's Avatar
So you have an 89 na but your name is 88 na??
Anyway, I want you to try this: take off your air pump. Give it a spin by hand. Spins free and easy dont it? Thats how much energy your engine takes to spin it. No much at all. I guarantee you wont feel it with the butt dyno. Now, with the air pump off, go for a ride, being sure to tach it out a few times. Runs slow as **** ont he top end dont it? Also note that without the air pump belt, the water pump has a greater opportunity to slip, causing possible overheating concerns. Wanna lose an engine over 1/10 of a horsepower?
Return home and re-install the air pump :-)
Old Dec 1, 2001 | 09:47 AM
NCsublime's Avatar
Yeah, I agree with the previous post. Leave it on unless you wire open the 5th and 6th ports, or set them up to open electronically.
Remember we are only trying to help you do what's in your best interest. No one is discouraging you.
Derek
Old Dec 1, 2001 | 01:08 PM
Rx7-88na's Avatar
ok -- thanks, yeah when i made my name i didnt even have an 89... i dont know what happened... Not sure why I typed 88... I was in a hurry... oh well, it doesnt bother me...
Thanks for the info... I was really just looking to clean up the bay a little...but i will definetly leave it on now.. thanks fellas
Old Dec 1, 2001 | 01:55 PM
SIX TWO SLEEPER's Avatar
what's better is that you can use the air pump to push air in the intake instead of exhasut, so you get a slight supercharger effect. pretty cool. i did this once.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
12abridgeport
Aug 17, 2015 06:28 PM
