Sponsored by: CARiD
my rx-7 has poor idel
Old Sep 23, 2004 | 04:13 PM
chrisw80's Avatar
Talking my rx-7 has poor idel
Hi
I have a 1987 rx7 turbo and it has realy poor idel for some reason. I cant figure out why when i start it the car makes a squeeling sould and it starts and idels @ 1 and 1/2 for a few seconds and than goes down to just above 0 for a few secinds and i guss its spost to do that but that the car shakes realy had and dies after ideling at just above 0 for a few seconds. dose anyone know how to fix this or even know what i am talking about thanks.
Old Sep 24, 2004 | 10:46 AM
95R2-89TII Ground Zero's Avatar
Banned
1. Have you looked at the plugs yet? Color?
2. Was there anything that you did and then the car started acting this way?
* try adjusting the idle stop screw on the TB to keep the car running, and then begin the check up process.
Old Sep 26, 2004 | 07:58 PM
chrisw80's Avatar
whats the checkup process?
Old Sep 27, 2004 | 07:46 PM
DerangedHermit's Avatar
Look in the archives of the 2nd gen section. There's something about "idle troubles" or similar. That'll fix your problem.
The squeeling might be a belt. Is it high pitched?
Old Sep 29, 2004 | 11:42 PM
chrisw80's Avatar
yes, its high pitched
Old Nov 11, 2004 | 05:26 PM
deetz's Avatar
when my car did that it was the intake gasket was blown theres a way of testing it u take a glass of water and start the motor let it idle and pour sum water directly behind the thermostadt housing
and if the car dies its cus its blown
respond back if it dont theres other tests
Old Nov 15, 2004 | 05:14 PM
brent clement's Avatar
Fabricator and builder
Also check your water pump. Mine squealed like hell when it died.(didn't stall though)
Old Nov 16, 2004 | 06:40 AM
Whizbang's Avatar
Respecognize!
have you tried moving the letter "E" in front of the letter "L"? That might make your idle better :P
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Bauer778
Nov 4, 2015 04:42 PM
Duc852
Sep 22, 2015 03:49 AM
RedBaronII
Sep 20, 2015 11:29 AM
