Sponsored by: CARiD
question about iridium spark plugs
Old Sep 20, 2004 | 04:37 PM
mightymouse0x's Avatar
wish my car was faster...
Question question about iridium spark plugs
did a search about iridium spark plugs, and got even more confused. im in a need for a tune up, badly, and well im looking at iridiums, i got the money but dont know if i want to spend it on that. i know it makes minor differences like smoother idle, and a bit more power, etc. ive been hearing about the BR10EIX model type, that goes on some bikes. i thought rotary sprak plugs had to be flat at the end, does it not have to be? anyway heres my question:
-why should i pay $30-35 for special rotary iridium spark plugs, when i can just get the BR10EIX for $7?
-would 10 be the best heat rating for my list of mods? ill also be getting an exhaust soon.
-and what kind of gap should i use if i use the BR10EIX?
Old Sep 21, 2004 | 12:30 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
unless you've got more than 400 to the wheels, you'll be fine with either stock plugs or all trailing.
Old Sep 21, 2004 | 06:41 AM
thank but can anyone else answer the other questions? if i can get the $7 iridiums, or pay$4-5 bucks for regular, im going with iridium. but is that the right kind i should get, BR10EIX? and is this heat range fine?
Old Sep 21, 2004 | 01:44 PM
the 10's might foul out. also, they're the conventional style-which shrouds the spark from the combustion area making it a little harder to ignite and slightly less efficient.
Old Sep 21, 2004 | 03:52 PM
so i should go with the ones that are made for the rotary, the flat kind? and i should probably get a 9 then?
Old Sep 21, 2004 | 04:33 PM
what do your plugs look like now--are you burning them out?
Old Sep 21, 2004 | 05:25 PM
havent pulled them out yet, they were slightly used sparkplugs from my old motor, and then i a rebuilt turbo motor, and i have a about 10k on the motor, along with whatever else i had from the first motor. and its starting to drive a bit rough.
Old Sep 22, 2004 | 05:02 AM
10k??
i change mine every other oil change. LOL
seriously though, take a good look at them and see what they look like. i'm thinking you'd be ok with stock plugs though--at least for now.
Old Sep 22, 2004 | 08:16 PM
I wish I was driving!
Installing the RX-8 Iridium plugs over new stock plugs on a mildly modifed S5 TII was worth 4 hp on the dyno. Idle and top-end was slightly smoother too.
These plugs cost $280 Cdn at the dealership... that's about $200 USD for all four.... However, they don't seem to be showing signs of wear near as quickly...
Old Sep 22, 2004 | 08:47 PM
that's $50/hp!!!
Old Sep 23, 2004 | 08:46 PM
RotaryWeaponSE7EN's Avatar
HKS also makes iridium plugs for the fc's.
Old Sep 28, 2004 | 09:13 PM
RETed's Avatar
Cause the reach on those bike plugs are not as long as the rotary specific ones...
-Ted
Old Oct 6, 2004 | 08:48 PM
afaik iridium plugs don't make much difference performance wise, the main advantage is longer life of the plug because of the conductor material being harder to burn away over time. I wouldn't bother going much more than oem plugs, heat range you should check the plugs condition (fouled or overheated?) before you decide what heat range to use.
Old Oct 6, 2004 | 11:11 PM
but the insulator still goes away...and broke off on 2 of mine when i tried them.
Old Oct 22, 2004 | 07:41 PM
Max13BREW's Avatar
FDrx7.com
Talking to my local Rotary guru, I am in the process of placing 4x RX8 plugs in my Series 7..
However I have managed to get them for $20 aus each which is about $14US each...(Considerably less than the $50 US each quoted above...)
Old Oct 27, 2004 | 10:46 AM
SureShot's Avatar
Seduced by the DARK SIDE
The best value I've found - good for ~4 oil changes.
(leading) NGK BUR7EQP - platinum - from Advance Auto Parts - $6.95 each.
(trailing) NGK BUR9EQ - standard - $4.95 each.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
alphawolff
Nov 17, 2015 05:57 PM
Joe428
16
Aug 19, 2015 06:24 PM
