ATTN: those with RE-Amemiya sleek lights
Old Nov 26, 2001 | 11:05 AM
A-Spec's Avatar
I know they use IPF motorcycle lights but what bulbs do they use??
tks,
David
Old Nov 26, 2001 | 11:36 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
h3 bulbs
Old Nov 26, 2001 | 11:46 AM
A-Spec's Avatar
H3 for both high and low? man so they are like fog lights! have you thought about putting these in?
they are 90mm and I think it's very similar to the RE....
David
Old Nov 26, 2001 | 02:40 PM
Bacon's Avatar
IRS 4 Life
those would be GREAT...
b/c they are a high and low beam, not like re-s that are foglights or my Bacon sports kit wich uses driving lamps
+++ thesse lamps use what looks like a 9007 bulb ( real headlight bulb) b/c thats deffinetly not a h3 bulb thats in there...AAAHHHHH how come i find them now, owell
damn hmmmnnn mabe ill re-do mine, or just buy the mazdaspeed hid kit
Old Nov 26, 2001 | 02:46 PM
Bacon's Avatar
IRS 4 Life
ahhh just found the page
90mm High and Low Beam Headlamps for Custom Applications.
These headlamps are DOT compliant but the lighting pattern is near indistinguishable from the European ECE lighting pattern
so technically if you had these @ the right height they would be legal!!! wtf im pissed @ my self now
ohh they use h9 bulbs @ 65 wats, they would be sweet headlights
Old Nov 26, 2001 | 02:53 PM
dclin's Avatar
Perpetual Project
Hey! These are the Hella hi/lo beams found in their kits, right? Damn, I was wondering where to get them. Also good to see what they look like on the back side/mounting/etc.
They have also an HID kit for Audis and the Focus that uses these assemblies - so that means we can get HID that has bulbs properly positioned, not some aftermarket 'drop-in'.
Someone forward this to Jim - I thin he's working on an Unobtanium light kit.
Old Nov 26, 2001 | 04:52 PM
A-Spec's Avatar
well for those interested, here's a very informative site about the hella 90mm.
http://faq.auto.light.tripod.com/hella-90mm.htm
it has all the different versions of it listed. Dclin, wish I found them before I bought your HID!! The HID was blinding everyone in sight so I'm getting the east bear and going to fit the hellas in there and probably use the HID as extra light for late night mountain drives.
David
Old Nov 26, 2001 | 09:11 PM
wptrx7's Avatar
Newb Photog
for bacon ans aspec, are those housings for the bulbs for sale somwhere? can you purchase those for h4 bulbs, cause i have the catz ballast system and i would love to try to make my own housing like the re amiya kits. (ps if i do make this kit i will not distribute this because i am to lazy to make it for a bunch of people, even if it invoves me making money. i'll probably end up buying the housings and never doing **** with it and end up buying the re, if you have info on them give it to me anyway, i'll try.)
luigi
Old Nov 26, 2001 | 09:12 PM
wptrx7's Avatar
Newb Photog
for bacon and aspec, are those housings for the bulbs for sale somwhere? can you purchase those for h4 bulbs, cause i have the catz ballast system and i would love to try to make my own housing like the re amiya kits. (ps if i do make this kit i will not distribute this because i am to lazy to make it for a bunch of people, even if it involves me making money. i'll probably end up buying the housings and never doing **** with it and end up buying the re, if you have info on them give it to me anyway, i'll try.)
luigi
Old Nov 26, 2001 | 09:24 PM
Bacon's Avatar
IRS 4 Life
http://www.susquehanna.com/susq/hella/headlamp.htm
its towards the bottom
Old Dec 22, 2001 | 12:39 AM
Chron's Avatar
wptrx7... may i ask... how do you make the housing?
Old Jan 1, 2002 | 04:12 PM
Chron's Avatar
Hey guys.. im planning on getting the Hella 90mm, but im worried about the wiring.. does anyone know how? like for hi beam and low beam?
Old Jan 1, 2002 | 06:14 PM
DefBringer's Avatar
Bacon, what light kit is that on the car you posted? The 2nd picture? Is that the HID kit? Are there any more pictures from a better angle??
Old Jan 1, 2002 | 07:56 PM
1FAST7's Avatar
David
can those fit in the RE-Amemiya sleek light? I like those projector-style light!!!!!!!!
1FAST7
Old Jan 1, 2002 | 09:34 PM
Bacon's Avatar
IRS 4 Life
chron all u need to do is pull off wiring clip to headlight find out wich is ground and then click on lovs and with a voltmeeter or circut teaster figure wich wire is high and wich is low
defbringer
their BACONSPORT light
aka home made
no hid i wish
just 100w eurolite bulbs in all the lights
like a rally car @ night
Old Jan 1, 2002 | 09:49 PM
Mr. Stock's Avatar
1993 RX7 R1
Bacon,
Are you selling the Baconsport light kits?
Or is there a how-to on this mod?
Thanks,
Ed
Old Jan 1, 2002 | 10:22 PM
Bacon's Avatar
IRS 4 Life
check here for a small write up
https://www.rx7club.com/vforums/show...threadid=40512
mine dont go up or down right now, b/c im 2 lazy to fix my design flaw..ill sell mine if u reall want them for 400 bux shipped
for the whole assembly bulbs and all
Old Jan 1, 2002 | 10:29 PM
dclin's Avatar
Perpetual Project
1FAST7
Its not just the fact that the RE (and basically every other kit) uses fog lamps, its how the lights are positioned. The lamp assemblies are sunk so far into the body that little of the usable light makes out onto the road. They definitely look cool, but less functional.
The stock lamp assembly opens higher and forward of the RE lights, and therefor can 'see' more of the road. Unfortunetly in the case of the stock assembly, the optics (reflector) SUCK.:p
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
