Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Recommendations for use w/supercharger?
Old Nov 24, 2001 | 09:09 PM
SuperchargedRex's Avatar
Chief Knucklehead
Question Recommendations for use w/supercharger?
I know I'm an oddball with my supercharger, but what computer would you guys suggest? I'm currently running just the factory computer, and I think I could tweak a few more hp out of my setup with a programmable fuel/ignition setup. I've thought about a piggyback like the Apex Super-AFC, or going all out like a Haltech, but I'm not sure. Suggestions?
Old Nov 24, 2001 | 10:18 PM
Chuck,
If you are looking for more power and reliablity, go with the haltech.
You can control the timing and fuel much better, your car will run more richer from the beginning with the haltech. Something the stock n/a ecu can't do unless you start playing with the fuel pressure and fooling it.
Is the best bang for the buck. Does you engine have a lot of miles?
C
Old Nov 24, 2001 | 10:56 PM
vosko's Avatar
Just Call Me Terminator!
his engine has a fresh rebuild. i would get a haltech, you can bigger injectors and the car will run alot better and safer
Old Nov 25, 2001 | 07:23 AM
Chief Knucklehead
Vosko's right, its a fresh rebuild. I'm running the factory 460cc/min primary injectors, 550cc/min secondaries, Paxton's BDFPR, RP fuel pump, and it runs very rich.
The reason I was thinking S-AFC was that my boost profile is pretty much linear compared to rpm, and I think it would be easier to install and tune, provided I got a better O2 sensor to work with.
Old Nov 26, 2001 | 07:18 PM
RX794's Avatar
NYC's Loudest FD
Just get a S-AFC and tune it down on a dyno so that it doesn't run so rich, that's pretty much all you need, Haltech is good, but you will have to depend on someone to install, tune it and if something goes wrong with it, well you know. I guess I just don't like depending on other people, if it's just running rich get a S-AFC, install it yourself, and it'll solve your problems. BTW I know your car, I used to see it at the previous shop you used to take it to, I hope you got rid of that stupid catalytic converter by now, it was costing you HP. BTW if you need more fuel just get a HKS AIC, Greddy Rebic 4, or a Haltech F5 to control some additionals.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
rotor_veux
Sep 28, 2015 09:25 PM
Sammy Built
Haltech Forum
Sep 28, 2015 03:18 PM
