brake porprotion valve (sp?)
Old Jul 22, 2004 | 06:55 PM
rxseven07's Avatar
Registered pimp
hey i know of a valve that levels out the brake fluid that goes to each wheel, but dont know where to get it. i want my car to stop level. like when i slam on my brakes, my nose dips. so does anybody know where to get this valve?
Old Jul 22, 2004 | 08:09 PM
RX7145's Avatar
-SE with Mods
Summit Racing Sells them. http://summitracing.com/
Here is my setup:
Old Jul 22, 2004 | 08:10 PM
KaiNalu's Avatar
Check out this site http://www.ground-control.com/?D=29b...85f81bae188263
Old Jul 22, 2004 | 08:21 PM
Dom's Avatar
Dom
callin' tokyo
The proportioning valve is there to regulate the front to back pressure on the brakes so that all the tires lock up together.
The nose dipping problem you have is a suspension problem. Get stiffer springs and better struts.
Old Jul 22, 2004 | 09:00 PM
Rx7carl's Avatar
Airflow is my life
The dive is from soft springs up front. Weight transfers forward under braking. This is normal.
Old Jul 22, 2004 | 09:40 PM
rhinor61's Avatar
The major design issue with rear disc brakes is that is incorporates the park brake mechnicals which prevents the rear piston from free floating like the front calipers.
Even with a brake prop. vavle you still will have a not be able to get the car to squat when under hard braking, so it will still have a tendency to put more braking to the front, or lock up the rear tires.
John
Old Sep 15, 2004 | 11:18 PM
TReX7's Avatar
Beating a dead horse?
I hope I'm not beating a dead horse, but I have done search after search after search.....well, anyway, where can I get a stock brake proportioning valve for my 85 GSL-SE? Please help...dealer part only?
T
Old Sep 15, 2004 | 11:40 PM
rhinor61's Avatar
Dealer or buy a used unit.
Why are looking for a replacement unit?
John
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
