Leaky Oil Metering Pump?
Old Jul 22, 2004 | 12:15 PM
msmcgill's Avatar
Lightbulb Leaky Oil Metering Pump?
I recently removed and reinstalled the oil metering pump on my '84 GS 12A. During the process, I applied a thin film of sealer to the existing gasket - in an attempt to stop a small leak. It helped, but now I am noticing fresh oil on and around the pump linkage & spring. Does anyone know if these pumps can be rebuilt to stop a leak? Are there internal seals or gaskets that can be replaced? If possible, I'd like to try that before I lay down $150 for a new pump. Any ideas would be appreciated. Thanks!
Old Jul 22, 2004 | 12:26 PM
brownmound's Avatar
Anytime baby!
bada bing bada boom does this help?
http://www.godofredo.com/mound/3-11-03.html
right on.
Old Jul 22, 2004 | 12:41 PM
msmcgill's Avatar
AWESOME. Many thanks!
Old Jul 22, 2004 | 01:23 PM
bizarro's Avatar
yeah...brownmound's website helped me out alot! especially with the omp part
Old Jul 22, 2004 | 05:51 PM
brownmound's Avatar
Anytime baby!
Glad I could help. Right on.
Old Jul 22, 2004 | 06:13 PM
1984se's Avatar
Ryan
Let's put this in the FAQ page.
EXCELENT WRITE UP x 2
-Ryan
Old Jul 22, 2004 | 07:59 PM
bouis's Avatar
Yeah, but, really, 99% of the time it's just the gasket. Get a new one!
Old Jul 22, 2004 | 08:17 PM
msmcgill's Avatar
Yes, I'll put on a new gasket, too. But it appears that there is a leak coming from the vicinity of the linkage/spring and no evidence of oil around the edge of the gasket. It's dripping off of the spring. Thanks for the suggestion.
Old Jul 23, 2004 | 12:59 AM
brownmound's Avatar
Anytime baby!
Yeah, sounds like it could be that O-ring that is part of the Lowe kit. Give it a try....you may even be able to find a similar O-ring for cheap.
Right on.
Old Jul 23, 2004 | 09:13 AM
sgieldon's Avatar
I also bought the Rebuild kit and Have Never Had A Problem with it.
Peice of Cake to Rebuild.
(Just Make Sure that you use some Fresh Oil on ALL The Internal Parts) I Talked to them and they said if you don't you could end up with the stuff inside not sealing right. i.e. Back to Leaking Again.
One of the Best $15.00 Projects.
To bad there not all that Cheap.
sgieldon
steve
Old Jun 10, 2007 | 08:59 AM
xberserker's Avatar
SNIKT!
Looks like the webpage is gone. Does anybody have the info for this?
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 31, 2015 07:49 PM
