PLz help with offsets for Gram lights 57pros
Old Jul 19, 2004 | 09:57 PM
rotoboy661's Avatar
Unhappy PLz help with offsets for Gram lights 57pros
hey guy i need your help on this issue
ok im planin to get gram lights 57 pros but i have trouble figuring the offsets for these wheels
ok heres the sizes i want to run, and i did roll my fenders
rr: 18x10 fr: 18x9
and also what size tires to run also
i was thinking
rr: 275/35/18 fr: 235/40/18 or 245/35/18
thanx for any advice or inputs
mike
Old Jul 19, 2004 | 10:09 PM
7racer's Avatar
here...
https://www.rx7club.com/forum/showthread.php?t=287572
he has the offsets in the thread
you might want to PM him as he is selling them
https://www.rx7club.com/forum/showthread.php?t=313901
Old Jul 19, 2004 | 10:12 PM
gofast-'s Avatar
wow thats a lot of tire..
i'd run 235/40/18 front and 265/40/18 rear if i was making ~380whp
you could run 18x9 +15 and 18x10 +19 and it'll look good.
you'll have to roll pull and bang the fenders a little and runs ome camber to fit them
btu they'll look HOT HOT HOT
Old Jul 19, 2004 | 10:34 PM
rotoboy661's Avatar
wow that guy is runin 255/35/18 on the fronts with +40
is that possible any rubbing???
Old Jul 19, 2004 | 10:48 PM
spoolin93r1's Avatar
i have 9's and 10's on mine. 255/35 and 285/30's. offset is +40 front and +38 rear. no rubbing as long as ya roll the fenders
Old Jul 19, 2004 | 10:54 PM
7racer's Avatar
are you being serious?
Old Jul 19, 2004 | 11:16 PM
SpeedKing's Avatar
Power Trippin'
Wow, that's a lot of BS.
rotoboy661: I don't know what offsets Gram Lights 57 Pros come in, but to be on the safe side, you'd need a minimum of a +45 up front, and a +43 out back.
As far as tire sizing (w/ the above offsets):
255/35-18 Front
275/35-18 Rear
Old Jul 20, 2004 | 12:02 AM
rotoboy661's Avatar
Smile
255/35-18 Front
275/35-18 Rear
hey thaNX speed
um, on the offset chart it says
front: +40 or +43
rear: +38 or +40
Old Jul 20, 2004 | 12:49 AM
SpeedKing's Avatar
Power Trippin'
Originally Posted by rotoboy661
hey thaNX speed
front: +40 or +43
rear: +38 or +40
+43 up front will be *close*, and you know, every car is different. You may rub, you may not.
+40 for the rear, but you may need aftermarket trailing arms and toe links. I had 17x10 FM/5s +43 w/ 275/40-17, stock TA and TL and and no rubbing.
Only surefire way to avoid rubbing will be to go w/ a narrower width at those offsets (8.5" front/9.5" rear) or those wheels w/ a higher offset if available, but if not then forget 'em. My $0.02.
Old Jul 20, 2004 | 02:18 AM
rotoboy661's Avatar
thanx
ill keep everything u said in mind
Old Jul 20, 2004 | 09:34 AM
gofast-'s Avatar
i guess you guys dont like to work to make your cars look good and like sunk wheels?
why is it bs? because you havent seen it before?
17x10 +12 all around fits on an FC...an FD would be able toe ven take the same offsets..
why i sit that you guys call bs on everything?
Old Jul 20, 2004 | 12:12 PM
rynberg's Avatar
You're a moron.
Old Jul 20, 2004 | 12:19 PM
rotoboy661's Avatar
Originally Posted by rynberg
You're a moron.
:laugh:
Old Jul 20, 2004 | 12:52 PM
Boosted!'s Avatar
i have 18x9.5 rear 18x8.5 front with 265/35/18 rear and 235/40/18 front. mercury Volk te37
Old Jul 20, 2004 | 12:56 PM
7racer's Avatar
please tell me your not serious!!!
Firstly a FC isn't a FD in fitment. Additionally, while I do like the lowered look, I don't want to do extra body work and would like to be able to TURN my front wheels without hitting any sheet metal.
17x10 can be done but with coilovers and aftermarket trailing arms and toe links...BUT NOT AT THOSE OFFSETS!!! That's what everyone is saying and calling bs to you. Even with around +40 you would have most likely need rolling the fenders to get it to fit...
and when you mention toe in I assume you actually mean camber? Even with that I don't think it would fit unlessyou wanted a 4x4 look with the wheels sticking out past the car.
Old Jul 20, 2004 | 01:17 PM
RETed's Avatar
Go away.
Running a 225 wide tire on a 10" wide rim is just plain stupid.
I'm sorry you're so caught up on the drift look that you totally overlook tire manufacturer recommended wheel width specs.
10" wide wheel, even with the +12mm offset up front will NOT stay under the stock front fender.
That makes it ILLEGAL for most city and state laws regarding vehicle safety.
-Ted
Old Jul 20, 2004 | 01:26 PM
rotoboy661's Avatar
c'mon guys give this guy a break
jk
gofast-'s Avatar
nobody is obsessed wiht a drift look, its what i like i have it its what works.
it will stay under with proper suspension settings
i dont want to argue with you about what you think is right and wrong...because we obviously have different views.
Old Jul 20, 2004 | 01:34 PM
rotoboy661's Avatar
dude just post pics or ur setup
Old Jul 20, 2004 | 01:51 PM
rynberg's Avatar
Yep, we live in reality and you live in Never Never Land. Say hi to Michael for us.
Old Jul 20, 2004 | 04:15 PM
RETed's Avatar
You're posting the same pics S13_Slide is, so that already puts you in the wrong crowd.
Cut this guy a break?
Have you read the stuff S13_Slide has posted?
Why don't you go ask the tire manufacturers on what their recommended wheel sizes are for a particular tire model.
I wouldn't be surprised if your combo is not on their list.
-Ted
Old Jul 20, 2004 | 09:04 PM
gofast-'s Avatar
i am his friend.i never said it was my car
it is possible.
i have an s14.
Old Jul 21, 2004 | 12:02 AM
rynberg's Avatar
it is possible.
i have an s14.
Then why the hell are you spouting off on what fits on FCs and FDs....
Old Jul 21, 2004 | 12:17 AM
RETed's Avatar
it is possible.
i have an s14.
See...guilty by association...
You guys might be able to impress a bunch of kiddies on some other dori forum, but please keep this **** off here.
There are a lot of very experienced owners who know better, and your comments are an insult to them.
You might want to try some grip driving on a road racing track to see if your dori skills are good enough.
Don't be surprised you end up getting frustrated.
I welcome you to join any of the driving schools (Skip Barber, Derek Bell, etc.) sessions to see how good your driving skills really are.
-Ted
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
