Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
which stand alone uses MAP not MAF
Old Nov 16, 2001 | 01:11 AM
tweaked's Avatar
what stand alone managment systems use the Manifold Air Pressure sensor instead of Mass Air Flow sensor?
I have a 1988 n/a
Old Nov 16, 2001 | 07:33 AM
13BAce's Avatar
On a long vacation
Re: which stand alone uses MAP not MAF
I have a 1988 n/a
All of the popular ones--Haltech, Wolf, Electromoitve--use MAP sensors.
Old Nov 16, 2001 | 01:04 PM
tweaked's Avatar
any specific recomendatons? I am about a modded as you can get with bolt ons for n/a. next is a lighter aluminum fly and rotors and porting
Old Nov 16, 2001 | 01:52 PM
13BAce's Avatar
On a long vacation
EvilAviator knows of somebody using a Wolf 3D on a non-turbo car. The TEC II is a nice system, but it needs some work to get it set up correctly.
Old Nov 16, 2001 | 06:02 PM
tweaked's Avatar
thanks
Thanks guys I will be net shoping this weekend.
Old Nov 16, 2001 | 06:57 PM
13BAce's Avatar
On a long vacation
Re: thanks
Let us know what you decide.
Check out:
http://www.wolfems.com.au/wolf_home_page.html
http://www.electromotive-inc.com/
http://www.haltech.com.au/
Old Nov 17, 2001 | 12:20 PM
Evil Aviator's Avatar
Rotorhead
Yeah, I rode along with the Florida Wolf dealer during tuning sessions on two different NA RX-7's. Yes, ditching the stock vane-type AFM really helps the performance! Also, NOTA944 on this forum has some experience with the Wolf on an NA.
I'm not sure what you intend to do with your 88, or what you want to spend, but now that the Wolf 3D 4.0 is about to be released, you may be able to pick up a used 3.x for a really good price (they are $1250 USD new). The 3.x will work just fine in your NA, but note that you cannot change parameters past 8K rpm. The 4.0 has better features, but will cost a couple hundered more, and will not be in full supply in the US for at least another month.
The Haltech E6K is also good, and there is probably a shop nearby to tune it for you. A lot of people have had good results with the TEC II, but personally I'm going to stay away from something that even Peter Farrell has trouble tuning.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
