What spring rates are these? (Ground Control)
My roommate bought a Ground Control setup, but somehow forgot what spring rates he got.
The numbers on the box are:
GC.150.64.66 (front)
GC.200.64.44 (rear)
Anyone know what spring rates these are?
Thanks,
Jason
GC.200.64.44 (rear)
Thanks,
Jason
never mind
I found it. The last set of numbers is the spring rate in metric.
So that would convert to 369 and 246lb/in for the front and rear respectively.
Re: What spring rates are these? (Ground Control)
64mm or 2.5" diameter
6.6 kg-mm spring rate
GC.200.64.44 (rear)
4.4 kg-mm spring rate
Multiply kg-mm by 55.88 to convert to in-pounds.
-Ted
rx8volks
Canadian Forum
09-01-15 10:46 PM
