run fuel pump without started car...how?
Old Jul 10, 2004 | 09:02 AM
how can i run the fuel pump with out starting the car on an 84 gs.
Thanks
Brad
Old Jul 10, 2004 | 10:01 AM
run power to it?
Old Jul 10, 2004 | 10:09 AM
bkm_rx7's Avatar
boost my 7
Pretty much like ^he^ said. Run some power back to underneath the car to where the fuel pump is. Its on the passenger side right in front of the back tire.
What do you need to run it for?
Old Jul 10, 2004 | 10:25 AM
RotaryRyan's Avatar
DSM
I have a seperate fused power supply for my pump with a switch right down and to the left of the steering wheel. I turn it on/off without even thinking about it now. Its weird, everytime i drive someone elses car i always reach down to turn it on/off and its not there
Old Jul 10, 2004 | 01:44 PM
Mezzano's Avatar
I hooked mine up directly to the battery to troubleshoot a starting problem I had once. I did fuse the link!! Use the wiring diagram for help on what wire is hot and which is ground.
Old Jul 10, 2004 | 02:52 PM
n/m i just kept trying to start it till i got my regulator down to the right psi...pluged the main fuel line back up and it started right up...and it might have been in my head but it sounds SO MUCH better... i was running very lean because my stock pump was dieing on my.
now im running a holley red with a holley regulator
Brad
Old Jul 10, 2004 | 02:55 PM
dp
Old Jul 10, 2004 | 05:32 PM
rotor vs. piston's Avatar
Function > Form
Also there is a plug under the dash that you can run a jumper from and that will turn on the pump without turning on the engine.
Old Jul 10, 2004 | 10:20 PM
GavinJuice's Avatar
Leave A Message
Check this out homeslice http://img15.photobucket.com/albums/...t=untitled.jpg
Old Jul 10, 2004 | 11:59 PM
password?
Old Jul 11, 2004 | 01:14 AM
GavinJuice's Avatar
Leave A Message
try this http://img15.photobucket.com/albums/...e/untitled.jpg
Old Jul 11, 2004 | 01:17 AM
...i got nothing from that but maybe i read it wrong...either way its down and over with...fuel system will be done tomorrow (puttin tank back on and im ready to go)
Old Jul 11, 2004 | 03:00 AM
Jeff20B's Avatar
Lapping = Fapping
Yet another '84-'85... thread. Sorry.
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
