clean tail lights
Old Jul 8, 2004 | 05:20 PM
Todd Staples's Avatar
"A Piece of Work"
clean tail lights
Is there an easy way to clean the tail lights on an 85? I have a little dust between the outside clear cover and the lights. Can these be seperated easily or not? Just don't want to be taking anything apart that I might screw up.
Thanks
Old Jul 8, 2004 | 06:16 PM
Bass's Avatar
Grey-Bruce Rotorhead
You need to completely remove the entire cluster as a unit. That's the easy part- just a few fasteners as I recall. Then you will need to use an exacto knife and cut the gasket for the lens. Go very slow, as the lense can be brittle. Clean everything out, and then replace the gasket with a clear flexible silicone. Make sure that you give it time to cure under pressure before you put it back on the car.
Old Jul 8, 2004 | 06:30 PM
Snapshot's Avatar
If you touch it it will fall apart later. Gluing the inner & outer lenses back together will fail almost immediatly. You need to purchase new units.
Old Jul 8, 2004 | 07:56 PM
Lotus00's Avatar
I used RTV silicon to hold my covers on, it works fine. They do come off kinda easily if you try to tear them off, but as long as you dont mess around with them too much they will be fine.
Old Jul 8, 2004 | 08:09 PM
Rx7carl's Avatar
Airflow is my life
ioTus' cardomain site details how he took his apart.
Old Jul 9, 2004 | 12:14 AM
high-RPM's Avatar
RX7 F0RUM > reallife™
anybody painted the lens of the light to make it a round light?? fd style?
Old Jul 9, 2004 | 12:45 AM
bkm_rx7's Avatar
boost my 7
Speaking of good 'ol ioTus, im finishing up my custom clear taillights. All you have to do for this mod is listed at Custom Clear Taillights by ioTus. He gives a well shown walkthrough and says the the single hardest part is getting the $%#$^& cover off the taillights. Anyways, i chose to go with a "cracked ice" style, and it turned out really well i think. I will be posting pics of it shortly, once i get everything back together and glued
Old Jul 9, 2004 | 12:53 AM
bkm_rx7's Avatar
boost my 7
Oh, forgot to mention 1 other thing. I think im gonna go with LEDs instead of colored replacement lights, what do you guys think about that?
Old Jul 10, 2004 | 10:59 PM
bamalama1's Avatar
Newbie
tail lights
Thanks for all the info, you guys are great.
TCS
Old May 6, 2005 | 10:41 AM
DiamJim's Avatar
I'm looking for Left rear fender light lens for 85 RX7 GSL SE. I brought 84 RX7 lens and they did not work. Despartely need lens for MD inspection.
