Engine Problem
Old Jun 26, 2004 | 05:50 AM
s2rx7's Avatar
Engine Problem
I just bought a series 1 1980 rx7, it has a 13b carbureted motor in it.
The engine will not start properly. The engine turns over alright when i try to start it. I can only get it to run if i pull the spark plugs out and put a bit of oil in each hole.
Could the engine be blown?
Lost its compression?
Or could there be something wrong with the ignition?
Old Jun 26, 2004 | 06:43 AM
QuagmireMan's Avatar
Registered Offender
upgrade you engine grounds, then replace the spark plugs, make sure you have fresh gas in there, and then crank away.
Old Jun 26, 2004 | 07:07 AM
tjgosurf's Avatar
Squeak, Suicide Girls
just curious a 13B in a 1980? did it have an engine swap?
Old Jun 26, 2004 | 02:18 PM
Jeff20B's Avatar
Lapping = Fapping
Of course.
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
Wicked93gs
Aug 17, 2015 12:14 PM
