Anyone know if the ring and pinion from a 4x114 rear end fit in the 4x110 rear end?
Old Jun 25, 2004 | 11:59 AM
Ben 84 RX-7's Avatar
I am pretty sure that the ring and pinion are interchangeable for any year first gen...the part numbers are the same from Mazda I think. But before I put down a bunch of money for a set I want to make sure!
Old Jun 25, 2004 | 03:59 PM
680RWHP12A's Avatar
yes the ring and pinion are interchangeable... the only difference is the brg. size on the posi unit itself
Old Jun 25, 2004 | 04:14 PM
The what? Sorry...I suck at internet abbreviations!
Old Jun 25, 2004 | 07:53 PM
Kill No Cone's Avatar
Ben,
If you do in fact have an 84 or 85 Rx7, then you can use the third member from a GSL-SE. But if your call is an earlier car the laster third will not work, becuase the earlier cars have smaller axles.
Old Jun 25, 2004 | 09:50 PM
Originally posted by Kill No Cone
Ben,
My car is an 84 with a rear end marked 83...probably from a junkyard for the discs. I am just making sure the ring and pinion itself will work. I can buy a third member with a 4.44 in it, and put the ring and pinion in my rear end. The ring and pinion work for all first gens right? That is my real question.
Old Jun 26, 2004 | 12:43 AM
Yes, the rind and pinon will work. If you google for "miata solo interchange" you can get an interchange chart that has part numbers that could help.
So, did you find a front third member from a four wheel drive pickup? I have been looking for one myself.
Th0m4s
Feb 26, 2019 02:04 AM
