BMW get their anti-det working
Old Jun 24, 2004 | 10:27 PM
rpm_pwr's Avatar
Remember the posts about research into Ion-sensing ignition?
Well BMW got it going:
Highlight in engine management: ionic current technology.
The ionic current technology featured by the engine management unit is a technological highlight which serves to detect engine knock, misfiring and combustion misses. Utilizing the spark plug in each cylinder, this system helps to pinpoint engine knock, to check for correct ignition and to detect any ignition misses. Thus the spark plug has a dual function – as an actuator for the ignition and as a sensor for monitoring the combustion process. The ionic current measuring is done directly during the combustion process. The so-called ionic current satellite receives signals from the five spark plugs of each cylinder bank. Dependent on the load, it amplifies these signals and transmits them to the engine management system for analysis, which, for example, perfectly adjusts the ignition point of each cylinder via knock control to the combustion process. All this results in benefits for the driver of the new M5 – lower fuel consumption, higher torque and enhanced performance.
Taken from the press kit for the forthcoming M5.
Apologies if this is in the wrong forum.
Old Jun 24, 2004 | 10:35 PM
jpandes's Avatar
Damn, I there isn't an "emoticon" that signifies "this **** is over my head"...
Old Jun 24, 2004 | 11:08 PM
rpm_pwr's Avatar
Instead of waiting to hear the pistons rattle, it figures out how close it is to detonation by how much current the spark plugs draw. Means they can run right on the limit the whole time completely safely.
Old Jun 24, 2004 | 11:17 PM
Kento's Avatar
2/4 wheel cornering fiend
Of course, we'd probably need a 32-bit processor to handle the necessary computations quickly enough for an ion-current sensing device...
Old Jun 25, 2004 | 02:44 AM
Assud's Avatar
That quote made my day.
Old Jun 25, 2004 | 09:26 AM
cymrex's Avatar
You can create a ion sensing ignition using a 16-bit microcontroller, texas instruments MSP430.
Want to DIY, see here: http://www.hut.fi/~vvartiov/ion/DIY-Ion-Sensing-2.pdf
Old Jun 25, 2004 | 11:05 AM
NewbernD's Avatar
Tequila? ..it's like beer
Saab has been doing it for years.
Old Jun 25, 2004 | 05:17 PM
InsaneGideon's Avatar
Still on 1st engine
Re: Saab
http://www.mecel.se/technologies/ionsense/default.htm
I belive Delphi has been doing this with their systems for a while now.
Knowing BMW's electrics, I wonder if it actually works.
That reminds me, wern't they promising to use an electric valvtrain a few years back?
Old Jun 25, 2004 | 08:17 PM
WaLieN's Avatar
Call me gramps!
If the TrailPlug can supposedly sell 60+ units @ ~$500, this technology would be worth at least [Dr. Evil voice]ONE MILLION DOLLARS![/Dr. Evil voice].
Old Jun 25, 2004 | 08:40 PM
peejay's Avatar
Old [Sch|F]ool
I thought SAAB had been using this technology since the mid-'90s.
Old Jun 28, 2004 | 02:13 AM
jhillyer's Avatar
This is fun stuff. I could potentially machete the ball of sensor weeds. No need for MAP, or O2. Knowing displacement, crank position, fuel dose, combined with sampling current in the chamber, defines the last ignition performance. A quick ECU would adjust the very next ignition.
Fuel timing could be adjusted for nearby injectors. The upstream secondaries on the 13B would be a pain, and I'd never tune so closely as needing the next injector pulse to be perfect, however.
Old Jun 28, 2004 | 12:07 PM
crispeed's Avatar
'Tuna'
So have Mercedez also.
Old Jun 28, 2004 | 06:04 PM
93 R1's Avatar
Yeah Mercedes has used it on the exclusively on their v12's (M137/M275) since 2000. It fires the plug normally at something like 120kV then a few milliseconds later it fires the plug again but at only like 10kV and interperets the "burn time" to tell if there is complete combustion.
Old Jul 1, 2004 | 08:19 AM
The_7's Avatar
Registered Piston Eater
im having a little trouble understanding how it can tell if there is complete combustion by measuring the current in the spark plug....???
Old Jul 1, 2004 | 02:45 PM
BLUE TII's Avatar
Rotary Motoring
Different combustion events produce distinct ions and you an analyze the ionic make-up by passing voltage through the gasses and measuring the affects.
Heedlessone
288
Sep 16, 2018 07:22 PM
GrossPolluter
Aug 15, 2015 10:32 PM
rx7jocke
Aug 15, 2015 03:36 PM
