sound went out
Old Jun 23, 2004 | 10:13 AM
thafox's Avatar
nother rican witha rotary
Angry sound went out
ok a few days ago i was drivin back home, the radio was on, lights outside since it was dark, and i had the window's down, then outta no where the car shut's off, nothin not even the hazards, next morning i check it battery's fine but one of the fuseble links is out, so it's replaced car starts right up, but then i go 2 leave i turn my radio on an there's no sound, also when i turn my radio on my clock dims.....ne suggestions on wha happend?
Old Jun 23, 2004 | 11:04 AM
thafox's Avatar
anybody?
Old Jun 23, 2004 | 11:32 AM
mwatson184's Avatar
holley guy
Check your main grounds, make sure they are making a nice connection. Could be a voltage regulator/alternator problem also. I'm not good at electrical stuffs, somebody else can help more.
Marques
Old Jun 23, 2004 | 11:46 AM
thafox's Avatar
i think the alt's fine cuz i've been drivin it for a few day's now without the same problem arising (knock on wood)
Old Jun 23, 2004 | 12:20 PM
Feds's Avatar
More Mazdas than Sense
Seems like something shorted/is shorting in the radio.
Old Jun 23, 2004 | 02:47 PM
Bass's Avatar
Grey-Bruce Rotorhead
Is the radio stock or aftermarket. If it's aftermarket, did you do the install?
Old Jun 23, 2004 | 08:46 PM
thafox's Avatar
stock everything ....yea im thinkin it's a cross short with the radio and the clock since they both share the fuse or whatever
Old Jun 24, 2004 | 06:15 AM
enigma32's Avatar
I dunno about the cross short idea...
But it does sound like there's a short or bad ground with the radio. (if the radio shorts, the current sink goes up, the voltage goes down, and the clock dims; if there's a bad ground, the radio comes on, the current sink increases (or tries to), the voltage decreases, and the clock dims :-))
Check ur wires. Do you have a voltmeter?
If you're not experiencing these problems with any other system, I would suggest that it's just something in the radio harness or the radio's ground.
hth,
enigma
Old Jun 24, 2004 | 09:37 AM
thafox's Avatar
yea i've got a volt meter....thnx for the input i'll check that 2morrow or saturday when i dont have nething 2 do right away
Old Jun 24, 2004 | 01:48 PM
nekky's Avatar
wtb 1g rx7 jdm shiz
Since you haven't said its NOT the fuse yet, I'll bet it's the fuse. Check it
Zac
Old Jun 24, 2004 | 02:52 PM
kiker14's Avatar
finally back in an RX-7!!
also, clean off your battery terminal. I was having some electrical problems and they seem to all have gone away since I scratched all the old crap off of my battery terminal (negative side only actually) with a screwdriver. Make the terminal shiney, and scratch up the thing you put on the terminal as well. i dunno if it will work for you, but it worked for me!
Old Jun 24, 2004 | 08:45 PM
thafox's Avatar
terminal's were cleaned on the battery and the post itself, i dont think it'll b a fuse since the display works fine there's just no sound at all
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
