need advice
Old Jun 22, 2004 | 09:46 PM
Newbie
Unhappy need advice
my 82 has no power at all i was needing advice on how to boost power w/out speending an arm and a leg.!>
Old Jun 22, 2004 | 10:54 PM
mazdaverx713b's Avatar
Have RX-7, will restore
welcome to the club. be sure to use the search feature in the future. adding a racing beat exhaust will no doubt add power. an aftermarket carb such a a weber or holly would be next and couple that with an intake manifold and a better fuel pump and regulator. dflids, and an electric fan and you are set for fun.
Old Jun 22, 2004 | 11:00 PM
BigJim's Avatar
trainwreck
When you say no power, do you mean NO POWER as in ir hardly drives, if so check compression, if you mean now power as in its jus tnot fast, add the word yet and youll be right. Exhaust from racing beat first
Old Jun 24, 2004 | 09:38 PM
Newbie
i mean no powe as in not fast but i thank you for your advice i will do that
Old Jun 24, 2004 | 09:47 PM
r0taryluv's Avatar
Mr.SEBoost
First thing is first....go through your maintence again. Fuel filter change,new plugs,wires,cap and rotar,and last but nor least new air filter. You will be suprised on what this does for the engine. This would be the cheapest performance mod to any engine. Once you have that done look into exaust. Racing Beat makes the best exaust for our cars with out a doubt. A little pricey, but dont skimp on the exaust, cause that is something underneath the car and you dont want to have to get under there every month to fix an exaust leak using cheap pluming. Hince our cars run at extreme temp. Once you get exaust going look into doing a cold air intake. Search the forum there are some pretty good write ups on what method you might want to go with. After these simple performance upgrades drive and enjoy it untill she dies and then street port the motor. Just my 2cents worth.
Keep r0tating,
Mike
Old Jun 24, 2004 | 09:57 PM
crackedoutducky's Avatar
well, at least i know what to save up for that helped me out guys! thanks
Andrew7dg
Aug 6, 2017 01:41 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
risingsunroof82
Sep 7, 2015 01:11 PM
