holley carb tutorial?
Old Jun 22, 2004 | 06:21 AM
Lt. Dan's Avatar
Hey guys, just got the Street Port package from Racing beat... It came with a holley carb, manifold, air cleaner, and a bunch of hardware... The instructions suck... Just curious if anyone has made a tutorial online about installing this setup...
Dan
Old Jun 22, 2004 | 11:13 AM
Alex-7's Avatar
I haven't herd of any tutorials for the RB intakes, but I did just install one on my 13B SE. I thought the RB instructions were pretty good, I had a couple of questions during the install so I called RB and they were very helpfull. The 12A kit might even be a little simpler (2 less metering lines and such)
Just bolt the carb to the manifold, bolt the manifold to the block (don't forget to change those O rings), hook up
fuel,oil,power brake vacume and your throttle linkage and it should fire right up.......mine did
Good luck,
Alex
Old Jun 22, 2004 | 08:48 PM
Lt. Dan's Avatar
did you have to remove the rats nest, or does that stay in place?
Dan
Old Jun 22, 2004 | 09:21 PM
kevinbtz's Avatar
Shell 93
you pretty much take all that crap off....all you have left is a carb intake vacume brake line, fuel lines, metering oil lines. and oh yea throtle and choke cable...
dona1326cosprings7
Oct 29, 2015 06:47 AM
